Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes
Appearance
Suspension, chassis & brakes — part of Z31 Performance & Upgrades archive (240 threads).
Threads[edit]
- "…and with that, shares in Work Equips plummeted overnight."
- '86 Slicktop with a bent frame. I need opinions.
- 14 inch wheels too small?
- 16x9..16x10 rare 3pc JDM Epsilon Southern Ways RIMs
- 2016 Big Brake Options
- 245/45/16 on 7x16 wheel?
- 26mm polyurethane front sway bar bushings
- 86 Z31T wheel wieght
- 87-89 Hubs for z32 brakes, curious question.
- 88 cali front sway bar
- 88t rotors not clearing cntrl arms
- Adjustable Toe and binding Reduction: Stage 2 Measure/Calcs
- Adjustable suspension interchange
- Aftermarket MBC
- Aftermarket Tie Rods and Adding More Angle
- Alignment Specs
- Alternative RLCA bushing sleeve
- Alternative S/Z/Q subframe swap adapter kit
- Any poly kits for the rear arms come with the sleeves?
- Any tricks to remove front strut inserts???
- Anyone running 17x10 +20 square setup? or 17x10/18x10.5 stagger
- Anyone worked with CCW ordering wheels?
- Asco solid sibframe bushings
- Axxis XBG are made in Aus!!
- Best braking options
- Best combination?
- Brake Hard Lines Rounded Off Nuts
- Brake Master Cylinder Built In Proportioning Valve
- Brake Upgrade Thread
- Brake bias
- Brake booster
- Brake pad review: Z32 Hawk Ceramic
- Brakes working too good…
- CV shafts..NAPA remfd?
- Caged !
- Cali wheel options after front coilover upgrade
- Can't decide on which wheel. (Another wheel thread)
- Can I use these tires? Got them for free
- Can this be fixed?
- Chattering, Loud, clunking CLSD differential
- Circuit Racing Rear Suspension
- Clarification on track width for different year z's
- Clearance on 18x9.0 + 18 Rims with 255/35/R18 Tires without spacers?
- Coil Over Suspenssion: Who makes it and a direct fit
- Coilover chassis compadability. Will these work?
- Coilover sleeve welding.....
- Confusing Calipers?
- Crossmember removal
- Crown victoria/ Gran Marquis mesh wheels on a Z31
- Current suspension options?
- DDing rear coilovers on bad roads
- DZ's you should buy these wheels thread.
- DZ - need wheel advice plz
- Damper settings on your coilovers
- De-powered rack for drifting.
- Delrin passenger side rack busing makes driver's side rubber wear out?
- Differences between Zenki and Kouki spindles on coilovers
- Double adjustable dampers into stance/powertrix bodies?
- Driven Authority WINFactory Z31 BBK
- Dust boots etc.
- Electric Steering
- FR 500 Wheels
- Fat Drift Rear Suspension
- Front Tokico Blue Strut Body Longer Than Stock?
- Front and Back tires different sizes
- Front camber question
- G-E's crazy rear multilink idea
- G35 Wheels : Any one using these?
- Good summer/race tires
- Harness bars…
- Has anyone found Bump Steer Spacers
- Help Completing S14 Subframe Conversion
- How would these wheels look on an SS?
- Hub bolts. Stock, new, replace?
- Hub question
- Identifying Rear Control Arms
- If i said i was making jigs for strutbars what would you say?
- If you could adjust steering, what's most important?
- Info on Ceika 1M Coilovers?
- Installing Kouki Tension Rods
- Isis coilovers/Stance parts
- Jacked up mastercylinder I suspect
- KYB + Eibach
- KYB Kit108A shock adaptor kit… anyone have them in stock?
- Koni yellow installation
- Level Zero poly motor mounts?
- Looking for some info on softer coil over spring rates for my Stance's ......
- Loosing brake pedal randomly..
- Lots of new stuff installed today but.....
- Lower Control Arms + Rear Flange type stuff
- Lowering with electronic suspension
- MORE RT stuff: Negative camber roll center adjusters!
- MR2 rear AGX inserts in 87-89 NA tubes for coilover sleeves?
- Manual Steering Conversion (Complete Guide)
- Molitor's Frame Rebuild
- Motor and transmission mount options for a DD
- Mustang springs
- Mustang springs under a z…
- My analsysis of Mauricio's trailing arm kit breakages
- N/A z31 for road racing
- NA/turbo brake booster
- Need Help on Wheel Fitment, i cant open AZ-Bum spec
- Need a measurement on Late model Z31 Rear Calipers
- Need help with rear control arm bushings.
- New Wheels for the Old Girl
- No brake pedal …
- Noob Stance Coilovers question
- Options for brake master cylinder
- Parts compatible with Front suspension
- Parts preferences on '87 NA
- Performance suspension without relocation of rear springs
- Pics of assembled s13 adapters - review before panicking!
- Poly spring seats in 2019?
- Possible rear rotor warping
- Possible to use 1 N/A Strut housing and 1 T housing?
- Post your new STANCE…
- Power steering leaks
- Powertrix Z31 RT Coilovers Review
- Powertrix oilover conversion needs.
- Question about watanabe wheel fitment
- REAR END SQUAT ON HARD ACCELERATION…
- Rail strengthening/modification
- Real reason for 87-89T hubs?
- Rear Camber Modification Write Up + Photo
- Rear MSA sway bar install questions
- Rear Spring Replacement
- Rear Subrframe Bushings
- Rear Suspension - alignment and rejigging
- Rear control arm
- Rear end drop
- Rear lower control arm bolts
- Rear subframe
- Rebuilding adjustable struts - need some info and pictures
- Reference
- Replacement Ball Joints, press fit
- Response Type Adjustable front control arm conversion progress…
- Response Type BIG BRAKE kit, 13 inches for non-turbo hubs :)
- Rethinking springs?
- Ride refresh
- Rim Size Recommendations 87 300ZX Turbo
- Rodend based outer tierods this week…
- S13/S14/S15 Subframe Conversion Kit GB-STANCE MULTILINK!!
- S13 Front Struts or entire Suspension/Steering
- S13 Steering Rack Bushings
- S13 coilover adapters.... groupbuy anyone?
- S13 coilover lower bushings are not universal
- S13 rear subframe
- SS Strut Tubes
- Scarry ceramic !
- Simple question, simple answer. I want vented rear brakes.
- Soo how about thems swaybars?
- Stance XR1 Front Coilover Dampening knob Relocation?
- Stance Z31 Tension rods - RD
- Steering rack sliding, what to use to scuff bushings?
- Steering slop and rear hub questions
- Strut Tubes
- Subframe Bushing Dimensions
- Suspension done, now time to look for wheels, suggestions?
- THe Basics: Z31 Suspension Options
- TSS Spring Pics
- TSS solid crossmember bushings question
- TSW Thruxtons
- T Top Infill?
- Tax return fun?
- The Wheel Thread
- The Z31 Wheel Show - many fine examples!
- The coilover thread.
- Thinking about cutting my stock springs?
- Those of you with coilovers?
- Tire options?
- Tires 18 … is this to big ?
- To those with solid subframe mounts - worth the money to upgrade?
- Tokico Illumina front strut installation trouble
- Tokico illuminas or bilstein?
- Toyota Soarer Suspension Transplant?
- Track Width Measurements?
- Trailing arm mods thread
- Trying to decide on new tires
- Turbo crossmember and core support questions
- Turbo crossmember differences?
- Turbo hub wheel seal problems
- WHEEL Offset Question
- Welcome Back Tokico
- What Struts and Springs? (Noobie)
- What Wheels are These?
- What are you running for STOCK SIZED (225/50/16) tires?
- Wheel Bearings Bad?
- Wheel and Tire options
- Which Shock/Struts should I get?
- Who's interested in TALLER rollcenter adjusters?
- Widest tire that will fit on 16 inch rim? 87 N/A
- Will these tires fit with svt cobra wheels?
- Will these wheels fit ???
- Wilwood Superlites
- Wrong strut tubes? Confirm?
- XXR 526 wheels..need a chop..
- Your pick will determine my buy! Choose!
- Z31 KONI Yellows
- Z31 Pillowball mount (camber Plates) on S13 Coilovers
- Z31 Tension Rod Progress
- Z32/S13/S14 - multi-link rear suspension swap
- Z32 Calipers....Ceramic coated and rebuilt (write up?)
- Z32 NA 26mm Air Gap Calipers
- Z32 front Suspension swap?
- adjusting pedal height and BMC rod???
- aftermarket z32 calipers??
- anyone ever shorten and rethread a strut shaft?
- brake booster alternative
- brake master leaking..again
- cobra wheels. 17x10.5
- coilovers with s13 rear end
- flatspotted tires
- front lower control arm
- gland nut
- is my strut bent?
- moar lowering a lowered 85t? advice plox
- msa sway bars
- optimal suspension geometry
- peugeot 607 brembo calipers on slip-on hubs
- pillow ball mounts
- quick info
- re: STANCE Question
- rear shock mounts
- rear shock noob quick question
- rear toe excessive
- refitting rear wheel bearings?
- rotor recommendations please (85t)
- seating rear half shafts
- spacer help
- spare tire on 35+ year old car
- steering knuckle
- steering rack mounts/bushings
- strut and springs change out -help
- vogtland springs…anybody use these or anyone have any info
- warped rotors
- what kind of springs are these?
- wheel fitment with s chassis swap
- where to buy performance pads?
- will a 87 rear turbo caliper work on a 87na?
- z31 s13 subframe swap
