Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Noob Stance Coilovers question
Imported from Z31Performance.com Forums{{#if:necrowizard88| — original post by necrowizard88}}{{#if:2016-06-15 08:30:19|, posted 2016-06-15 08:30:19}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/531136-noob-stance-coilovers-question.html|
necrowizard88: (2016-06-15 08:30:19)
Recently got my coilovers installed and can't really figure out how to adjust the dampening on the front. Apologies for the question but first time owning coilovers as a whole.
mtherkamp: (2016-06-15 13:06:24)
There should be a little hose-looking thing coming out of the bottom of the damper. You turn that to change damping.
necrowizard88: (2016-06-15 21:11:46)
Thank you, much appreciated!
adamvann3: (2016-06-16 17:57:07)
Fronts are inverted mono-tubes so the adjusters are on the bottom
Also, damping -- no one likes moist coilovers (good catch mtherkamp)
