Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Subframe Bushing Dimensions
Imported from Z31Performance.com Forums{{#if:NissanXRMA| — original post by NissanXRMA}}{{#if:2014-06-28 01:30:10|, posted 2014-06-28 01:30:10}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23952-subframe-bushing-dimensions.html|
NissanXRMA: (2014-06-28 01:30:10)
Would anyone be so kind to either list the dimensions of aluminum subframe bushings, or have a solidworks file/drawing? I'm planning on making a set when I have access to a lathe again.
Thank you.
G-E: (2014-06-28 02:50:43)
The total height can be anywhere from 68-71mm, the inner diameter is 21mm, the upper end is chamfered, and the body of the bushing will have to be 75.2mm…
You figure out the rest [archived image: smile.png]
NissanXRMA: (2014-08-06 01:41:54)
If anyone is interested in this as well, Gary had a drawing hosted of a spec'd poly bushing.
[archived image: bushingscompared.jpg]
Filipe: (2014-08-06 02:04:41)
^Good man. Way to share the knowledge.
G-E: (2014-08-06 02:13:29)
Except it's not entirely accurate [archived image: smile.png]
NissanXRMA: (2014-08-06 02:16:31)
Neither were you.
G-E: (2014-08-06 02:57:29)
If you're trying to make SOLID subframe bushings, measuring something squishy won't help will it?
NissanXRMA: (2014-08-06 12:22:10)
I never said it was.
G-E: (2014-08-06 20:59:39)
I don't understand, I gave you actual dimensions that fit, how was I wrong?
NissanXRMA: (2014-08-07 02:45:51)
You couldn't describe it in a better way? Or list all the dimensions (larger outer diameter of the annulus, length of the extruded larger OD, ect.) instead of saying "figure out the rest". There are only 5 dimensions.
Augustus Maximus: (2014-08-07 05:05:46)
No fighting or I'll come over and start bitch slapping
G-E: (2014-08-07 06:15:47)
{{#if:NissanXRMA|NissanXRMA wrote:|Quote:}}
… instead of saying "figure out the rest". There are only 5 dimensions.
I'm sorry I didn't give you irrelevant information, I'll try harder next time [archived image: smile.png]
Bunnies!
