Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/spacer help
Imported from Z31Performance.com Forums{{#if:onefast87| — original post by onefast87}}{{#if:2014-01-28 02:05:08|, posted 2014-01-28 02:05:08}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23261-spacer-help.html|
onefast87: (2014-01-28 02:05:08)
I picked up some varrstoens over the summer, and was wondering what is the best/safest way to do spacers??
i only need +5mm
if i use slip on spacers should i do longer studs??
adamvann3: (2014-01-28 02:08:58)
5mm is that no man's land. Some people use extended stud others don't.
If it were me I would run ichiba 50mm studs and ichiba 5~10mm spacer depending on how much room you really need.
Slip on hubs?
G-E: (2014-01-28 02:42:18)
Or… ask zach for my 60mm cromoly studs heh
onefast87: (2014-01-28 03:19:44)
http://www.frsport.com/Ichiba-NS-502…m_p_12867.html
Would this do the trick??
adamvann3: (2014-01-28 03:25:55)
All depends on what hub he is using. I have always swapped/upgraded to slip on hubs with all my cars. Much easier to work with.
onefast87: (2014-01-28 03:37:51)
I have an 88T
adamvann3: (2014-01-29 16:21:39)
Easy as pie then.
I would snag some longer studs to go with the spacer. Super easy to install on slip on hubs, plus if you ever end up using a 10mm or 15mm sometime you will be good to go.
