Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/strut and springs change out -help
Imported from Z31Performance.com Forums{{#if:jerryparks| — original post by jerryparks}}{{#if:2016-07-14 16:13:38|, posted 2016-07-14 16:13:38}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/531588-strut-and-springs-change-out-help.html|
jerryparks: (2016-07-14 16:13:38)
URGENT !! I need to know if '86 non turbo springs and struts will fit my 87 ZX turbo? I have got to obtain a smoother ride. I'm getting older and the rough ride is hard on my older body ! I have an 86 part car and thought I would just change out the parts. Help! I want to do this in the next couple days.
Z_Karma: (2016-07-14 19:34:29)
The entire 86na Macpherson strut assembly will be a direct swap to the 87 turbo. Just remove it at the 2 17mm* bolts from the steering knuckles,and at the 3 14mm* nuts on the upper mount.
  • wrench size, not thread diameter.
jerryparks: (2016-07-14 21:30:36)
Thanks Karma. This will save me a lot of work. - Jerry
jerryparks: (2016-07-14 21:32:41)
Karma: Are U sure no other bolts will have to be removed to take these out?
Z_Karma: (2016-07-14 22:33:15)
I'm 99% sure that i'm 80% certain.
You will have to use a screwdriver or pliers tp unclip the brake line retainer from the strut tube. You will also need to un -bolt the caliper bracket. That's 2 more 17mm bolts.
The lower control arm will be kind of held firm against the bottom of the strut assembly, a few whacks with a dead-blow mallet or rubber hammer should help separate it.
https://dev.z31library.com/xenonzcar_archive/z31/fsm.html
Disassembly instructions are in the FA section of the FSM(s) linked above.
