Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Jacked up mastercylinder I suspect
Imported from Z31Performance.com Forums{{#if:SATAN| — original post by SATAN}}{{#if:2007-05-09 00:48:08|, posted 2007-05-09 00:48:08}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/2347-jacked-up-mastercylinder-i-suspect.html|
SATAN: (2007-05-09 00:48:08)
Just put on all new stainless lines, new pads and TT calipers.
with car off (no clutch to drive around) I push in the pedal and it goes down pretty far. I then pump it up a few times and it feels good while I hold it in place. I release and wait for about 3-5 seconds and push it in again and it squishes down pretty far again.
Bad master you think?
Gregmatic: (2007-05-09 01:14:05)
yuppers, sounds like a seal is boogered up or just plain old defective.
Firehawk: (2007-05-09 09:35:42)
Yep. I don't know why so many are bad, even right out of the box.
Az4u2c: (2007-05-09 20:37:55)
sounds like the check valve inside is bad. I have one that i used for about two weeks and swapped off (i mistakingly thought it was the problem, tapered pads). It's been full of fluid in a box for a couple weeks but it should be fine. I'll sell it cheap. It was a VB new, not rebuilt. If you are interested PM me.
300zxt: (2007-05-09 21:34:51)
What's this, SATAN doing brake upgrades? LOL
SATAN: (2007-05-09 22:28:43)
Word up man!
Ever since I bought my 85t back in 2000 It has had brake issues. Swapped out calipers to 88t's, nothin. swapped out to a reman. master, nothing. Swapped out to TT calipers+ stainless lines nothin.
Gotta be the master.
Signal 12: (2007-05-10 00:08:15)
IT'S YOUR MASTER!!! DA DUN DUN DUN DA DA!!! 8)
