Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Loosing brake pedal randomly..
Imported from Z31Performance.com Forums{{#if:drifter| — original post by drifter}}{{#if:2014-02-13 00:05:14|, posted 2014-02-13 00:05:14}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23301-loosing-brake-pedal-randomly.html|
drifter: (2014-02-13 00:05:14)
so one day my seen that my caliper seal was broken and i had to get a new one. so i just keep filling my brake resivour up when the light went on until my caliper i ordered came in.
My brake light did not turn on one day and i ran it empty and lost all pedal. So when i filled it up that time. i still had no pedal even AFTER bleeding through a half gallon of brake fluid lol. (gravity bleed, machine vacuum and mechanically bleed all 4 and BMC). So along getting a caliper i got a reman master cylinder.
I replaced it the next day and i STILL had no pedal. I bleed it all 3 ways again still NO pedal. so i just drove it around in a parking lot for a few hours and BAM randomly i got a pedal again.
It has been 2 months and now i am slowly loosing a pedal and my e-brake does not work. NO LEAKS anywhere and everything is tight. i have half a pedal but it is going away. The only thing i noticed is my reman caliper…it is all sort of rusty now. while all my other OE calipers are not. i live in Florida inland no rust.
What in the world could it be better not say booster lol wouldn't the pedal be hard if it had no boost? [archived image: confused.png]
i r teh noobz: (2014-02-13 02:02:44)
Either its still got air trapped, or you got a bad BMC.
Make sure the brake pads all move freely and the slider pins aren't stuck. Pads rusted in place can cause a low pedal.
drifter: (2014-02-13 03:07:39)
okay ill check all of that tomorrow, is it true that if you have a brake booster vacuum leak you will loose a pedal?
