Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/rear shock mounts
Imported from Z31Performance.com Forums{{#if:xanmanz31| — original post by xanmanz31}}{{#if:2014-02-15 15:49:00|, posted 2014-02-15 15:49:00}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23325-rear-shock-mounts.html|
xanmanz31: (2014-02-15 15:49:00)
is ther any difference between the years and NA / T concerning the rear shock bracket? from what i can tell at courtesy parts theyre pretty much the same throughout
http://www.courtesyparts.com/kb_search_result.php?keywords=[55501H+\(z31&cPath=2317_2318_2412_2416]
NissanEgg: (2014-02-15 21:34:45)
There is a difference in the way the upper mounts are assembled between turbo and non-turbo. The FSM will a better picture of it.
Gregmatic: (2014-02-19 02:57:27)
The two piece mount used on the turbos was retarded. I still don't understand why they would 1) overengineer such a simple part 2) if it was so awesome then why would they install them on the turbos but not on n/a's?
But yes, there were two. Don't think the one piece mount was available from Nissan last I checked.
