Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Z32 NA 26mm Air Gap Calipers
Imported from Z31Performance.com Forums{{#if:85Turbo| — original post by 85Turbo}}{{#if:2007-03-22 23:31:52|, posted 2007-03-22 23:31:52}}{{#if:11| · 11 post{{#ifeq:11|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/1922-z32-na-26mm-air-gap-calipers.html|
85Turbo: (2007-03-22 23:31:52)
What does the air gap refer to? How are they different from the other aluminum Z32 calipers (besides them being 26mm vs 30mm)
There is a 90NA at the junkyard and they only want $10 a piece for them, im assuming they are a direct fit if im using 87 Turbo hubs, wheel bearings and rotors?
Thanks in advance.
zmech: (2007-03-23 01:01:10)
z
85Turbo: (2007-03-23 01:16:50)
If Slip on rotors refer to the 87-89 Rotors then yes I have them.
MrwassmanNA2T: (2007-03-23 02:48:48)
Swoop those up man.
zmech: (2007-03-23 13:36:35)
z
SteveZ: (2007-03-23 14:03:27)
Damn Im assuming you were at Pearl Rd?
I was just there last Friday and there were no Z32s so that must have been fresh.
I feel kinda silly now I actually just bought a rebuilt & powdercoated set on Ebay for $240 shipped :?
Im with Zmech on this one rebuild them, its pretty easy. And I have an extra set of SS Z32 front brake lines if you want them.
TODD03412: (2007-03-24 02:02:06)
[quote]SteveZ31 wrote:
{{#if:85Turbo|85Turbo wrote:|Quote:}}
You guys make me so mad !!!!!!
I cant believe you found those......did I ever mention that I grew up in Cleveland (willoughby) and everytime I read a post like this…that new branch my company is opening there looks better and better, plus I can watch the browns lose every weekend ! HA!!!
10 bucks, even if they didnt work…you could get them and make like 600% profit on ebay with a 3 day listing....get em !!!
85Turbo: (2007-03-25 14:31:22)
Todd, I would stay in Florida if I were you it gets to damn cold up here 8) .
I picked them up yesterday, they are in awesome condition even the pads looked pretty new!! I am just going to rebuild them as suggested, I already ordered a rebuild kit from Nissan.
thanks guys
SATAN: (2007-03-26 01:59:31)
Ok, with this link in mind http://www.princeton.edu/~asad/zbrakes/ which are the calipers that will bolt up to the stock 87-89 rotors? is it those 26mm ones? or the 30mm's Or will they all work and the 30's will just have to compress a little more?
Cause I just got these ones and dont know how wide they are yet.
http://cgi.ebay.com/ebaymotors/nissan-3 … enameZWDVW
85Turbo: (2007-03-30 20:20:55)
Ok I got the calipers and had them rebuilt, and I got a pair of SS Z32 Brake lines but I have a little problem..tthe end of the brake line is a female fitting and where the line should be bolted in the caliper is also female? So unless I have the wrong brake lines I assume I need a fitting to attach the line to the caliper? but when I took the calipers off the car I dont remember removing anything from the caliper besides the brake line itself and the two mounting bolts so I am confused. Can anyone tell me what the part # is on here? http://www.courtesyparts.com/betasite/i … 83_982_987
SATAN: (2007-04-11 22:31:30)
Man, I was about to PM you and ask you some stuff but it looks like you answered EVERY question I had in one single post BEFORE I even had the calipers! :shock: [archived image: biggrin.png] Except one. How did you pop out the little flare piece with out damaging it to reuse it in the TT master cyl.? I havnt tried yet but got it all apart and dont want to damage it trying to get it out.
THIS IS WHY YOU SEARCH PEOPLE!
