Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Asco solid sibframe bushings
Imported from Z31Performance.com Forums{{#if:ToiletFlush| — original post by ToiletFlush}}{{#if:2013-08-19 15:48:20|, posted 2013-08-19 15:48:20}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/22412-asco-solid-sibframe-bushings.html|
ToiletFlush: (2013-08-19 15:48:20)
Was wondering if anyone had tried these before and how they were suppose to fit in the subframe. Mine are loose enough on the subframe that im able to still take them in and out by had. Just wanted to know if its suppose to be like that.
Kutakino: (2013-08-19 16:57:37)
Mine were the same way, as far as I can tell I have had no problems from them. They greatly improved the feeling of the rear end.
nismopu: (2013-08-19 17:29:34)
They Were made to retain the sleeves from the old bushings but the next run wont be that way. I installed à set recently on my car without the sleeves and drive the car fairly hard with no Ill effects. It improved the tired rear suspension à ton and makes the car more enjoyable under acceleration.
ToiletFlush: (2013-08-19 19:28:00)
Awesome! Yeah I keep my sleeves in and it seems like they go in there snug but not tight enough to were I can't take them out anymore , glad to hear this is normal. What about noise ? Did you guys get any noise coming from the bushings ?
