Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Dust boots etc.
Imported from Z31Performance.com Forums{{#if:sp3cialfx| — original post by sp3cialfx}}{{#if:2014-06-04 11:59:15|, posted 2014-06-04 11:59:15}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23832-dust-boots-etc.html|
sp3cialfx: (2014-06-04 11:59:15)
WHen replacing shocks/struts on a 87 NA, what parts should I also replace - such as bump stops(?), dust boots etc. and where is the best place to get them at an affordable price/good quality?
I just bought Eibach Springs and KYB Struts/Shocks and want to make sure I have everything ready when I install.
Axel kain: (2014-06-04 12:29:54)
at least the boots are a good idea. I source www.rockauto.com for most things that aren't immediate.
floridaZ: (2014-06-05 02:21:30)
While you're down there, inspect the bushings, spring seats, tie rods, etc. for wear and replace as necessary. If you have time to go poly, you should.
