Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/rear shock noob quick question
Imported from Z31Performance.com Forums{{#if:samshadow| — original post by samshadow}}{{#if:2013-06-20 15:16:09|, posted 2013-06-20 15:16:09}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/21853-rear-shock-noob-quick-question.html|
samshadow: (2013-06-20 15:16:09)
Heyo,
Kinda dumb question about rear shocks. So my rears are bad and I merely want to replace them with some like KYBs or something till I can afford proper setup. Do I need to change the shock mount or will it be okay for a while? Also I need the adapter kit right? Sorry I'm new to the vehicle. Thanks!
Kimbro Slice: (2013-06-20 17:28:27)
Buy some Bilstein HD's or something designed for your vehicle and you don't need to do a thing.
Axel kain: (2013-06-21 00:16:31)
I have yet to need a "kit" to replace the rear shocks. Tokico blues, or KYB's should do you just fine. just do one at a time, and pay attention to how the top is assembled.
G-E: (2013-06-21 01:25:39)
Bilstein's are the least "affordable" of the stock replacement struts/shocks… tokico hp should do you fine
