Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/26mm polyurethane front sway bar bushings
Imported from Z31Performance.com Forums{{#if:kaur| — original post by kaur}}{{#if:2015-09-04 13:46:26|, posted 2015-09-04 13:46:26}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/25296-26mm-polyurethane-front-sway-bar-bushings.html|
kaur: (2015-09-04 13:46:26)
I'm looking at the bushings Prothane has for the Z31 but they don't list 26mm for front sway bars. What have you installed on your Shiros for example? Do their universal 26mm bushings fit the Z31 sway bars?
Darthpaul: (2015-09-26 04:04:02)
Measure your front sway bar and find a sort of average diameter. It will likely not be 26mm......
kaur: (2015-09-28 07:46:38)
{{#if:Darthpaul|Darthpaul wrote:|Quote:}}
Why would it likely not be 26mm?
I didn't take multiple measurements but the one spot I measured was 26 and the FSM also says it's supposed to be 26.
One of the local parts dealers offered me some Russian made (ООО Â«Полиуретан») poly bushings, I got them just to see what they are. They even have the correct part number on them. I also got the Prothane 26mm rear ones, which look very similar in terms of size but look a lot better. The Russian ones are smaller durometer; they feel quite soft. I'm probably going with the Prothane bushings as long as they fit, but if anyone ever wants to test these soft ones I can give them away.
