Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Rear subframe
Imported from Z31Performance.com Forums{{#if:spalding87z31| — original post by spalding87z31}}{{#if:2013-08-17 17:01:21|, posted 2013-08-17 17:01:21}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/22401-rear-subframe.html|
spalding87z31: (2013-08-17 17:01:21)
I'm in the process of replacing all the old rubber in the rear with poly do I need new collars for the rear subframe bushings?
Augustus Maximus: (2013-08-17 19:27:02)
What do your eyes tell you…are they in bad shape?
spalding87z31: (2013-08-17 23:46:57)
they are bad, was hopeing that i wouldnt need them with the poly bushing but looks like i need to buy oem bushing and get the metal off the rubber.
reddzx: (2013-08-18 00:00:04)
I think the new sub-frame bushing come with a collar
i r teh noobz: (2013-08-18 00:56:04)
They should come with the inner sleeve.
Careless: (2013-08-18 01:09:34)
my prothane lower control arms came with a sleeve for the outer bushings, not the serrated edged ones for the inner bushings. those need to be saved or pillaged.
G-E: (2013-08-19 12:59:27)
The prothane trailing arm bushings don't come with sleeves, the subframe bushings do
spalding87z31: (2013-08-19 13:37:17)
ok i order the subframe bushing the other day i should be good then, hopefully get it all back together this week after i sand blast and paint the subframe. Thanks for the info.
