Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Rear Spring Replacement
Imported from Z31Performance.com Forums{{#if:rsman| — original post by rsman}}{{#if:2014-07-01 19:08:44|, posted 2014-07-01 19:08:44}}{{#if:13| · 13 post{{#ifeq:13|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23974-rear-spring-replacement.html|
rsman: (2014-07-01 19:08:44)
Hey guys I have been re building my 300zx I bought a few months ago finally on suspension after doing fuel problems then brake problems. I am trying to replace the Rear springs on my car and cant get them off. I am using spring compressors but it seems that its not compressing it enough to be able to pop off. I looked for a how to but cant find one. if you know of one can you comment the link. if not does anyone have some advice and maybe pictures.
Thanks,
RS Man
Augustus Maximus: (2014-07-01 19:32:53)
Did you pull the shocks.
drb5721: (2014-07-01 19:39:15)
You could always un-bolt the rear shocks and let the rear subframe weight lower itself and from there work the spring out. Thats what I had to do. I also had the diff unbolted at the same time so there was nothing supporting the subframe in that area. There may be other options, but this is how mine came out easiest
rsman: (2014-07-01 19:43:55)
I had the shock unbolted not the diff… I will have to try that unless anyone else has any ideas?
PrideZ31: (2014-07-01 20:04:52)
We did this process on mine.
Remove the axle from the side with the spring you're trying to remove.
Place a jack under the control arm, and jack until you can remove the rear shock bolt.
Very slowly lower jack. Make sure you have something to keep the spring from jumping out if you don't have the spring compressors.
Got them out and in that way…
frostvectron: (2014-07-01 20:19:41)
No need to unbolt the diff when I did it.
Unbolt the shock. Then get the scissor jack from the spare tool kit and wedge it between the top of the control arm and the body (be careful of the brake lines). Give it a few turns which will push the control arm down. Doing this and using spring compressors you will be able to pull the spring out no problem.
rsman: (2014-07-01 20:31:41)
okay good stuff ill give those a shot this weekend hopefully last thing before the car can drive on the street
amreboot: (2014-07-01 21:53:07)
I have never had issues removing the rear springs before.
Never had to unbolt the shocks or diff.
I have cheap harbor freight spring compressors and they work just fine.
I had to get them each half way around the spring so that its an equal 50/50 compression.
But I suppose to make it easier would be to unbolt the bottom of the shock.
drb5721: (2014-07-02 14:23:48)
Keep in mind the reason my diff was unbolted was because it was being pulled to swap in LSD carrier. No other reason. I have no doubt that using the proper spring compressor will work. Unbolting the shocks should just allow for less spring compression to get the spring out.
Kimbro Slice: (2014-07-05 17:22:34)
Unbolting the bottom of the shock and then using your weight to push the trailing arm down should give the spring enough room to remove it without the need for a spring compressor.
flatfoot: (2014-07-06 14:34:57)
Don't forget to disconnect the swaybar as well as the lower shock mount before you push it down.
Axel kain: (2014-07-07 16:25:44)
Dont need spring compressors, with the shock unbolted from below, and the end link undone, just a little push down on the control arm, and the spring will FALL OUT of it's hole!
Filipe: (2014-07-07 17:55:55)
SMH. I didn't realize there's a rear sway bar? SO obviously I didn't undo the end links. It was a PITA. HUGE PITA. But doable.
