Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Ride refresh
Imported from Z31Performance.com Forums{{#if:Ohio_82| — original post by Ohio_82}}{{#if:2017-05-22 01:56:25|, posted 2017-05-22 01:56:25}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/535772-ride-refresh.html|
Ohio_82: (2017-05-22 01:56:25)
So im finally getting around to replacing my sub frame bushings and im wondering if while im at it i should just replace the shocks and springs all the way around. This is an 88 na car with a manual transmission. Im not planning a turbo swap or really any major engine upgrades this is just going to be a weekend cruiser type car. So what would be the best bang for the buck? Should i do the poly busbing kit as well?
Zuphoria: (2017-05-23 01:59:10)
Are the Shocks in the rear original? Replace them for sure! Z31 are terrible for rear suspension components needing replacement. Do all you can afford when you have the Sub Frame out!!
