Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Electric Steering
Imported from Z31Performance.com Forums{{#if:260DET| — original post by 260DET}}{{#if:2016-07-24 23:34:49|, posted 2016-07-24 23:34:49}}{{#if:1| · 1 post{{#ifeq:1|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/531682-electric-steering.html|
260DET: (2016-07-24 23:34:49)
Bit early with this but the topic has come up so here goes. Have decided that the V8 Z31 race car will have electric steering which has obvious advantages when doing an engine swap including allowing more forward sump space. There are kits around for the first model (S30) Z's, while it would be too much to hope that they would be a straight bolt in it does look like that the lower steering shafts are similar and have the same spline size. When the time comes if no kit is available I'll make my own. Pic is of a right driver S30 kit.
