Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Koni yellow installation
Imported from Z31Performance.com Forums{{#if:kmcguire| — original post by kmcguire}}{{#if:2013-08-12 02:54:06|, posted 2013-08-12 02:54:06}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/22361-koni-yellow-installation.html|
kmcguire: (2013-08-12 02:54:06)
I'm considering getting some koni yellows to replace my busted illuminas, but some of the general information I've seen indicates there's drilling and cutting of the strut assembly to install them. Is this really the case or is it a standard install with the supplied gland nut?
G-E: (2013-08-12 03:21:39)
They come with a new gland nut, no cutting required, just drilling out the nail in the bottom before you slip it in
Pace: (2013-08-12 13:02:14)
It's a straight forward procedure that is illustrated in the instructions. Nothing difficult.
Mine just seemed to be more interesting because I didn't get the supplied gland nuts - just had to crank down the stock ones and retighten them once the car was on the ground.
kmcguire: (2013-08-12 23:47:33)
Now this part just sounds perverted. :P
Thanks
G-E: (2013-08-13 00:09:24)
You're perverted if you think there's something wrong with slipping a big yellow thing into a hollow black thing
slammedcoupe: (2013-08-14 17:45:06)
isnt it usually slipping a big black thing into a little yellow thing?
[archived image: tumblr_mhy1gqCopC1s5vuldo1_500.png]
