Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Rear lower control arm bolts
Imported from Z31Performance.com Forums{{#if:Modelli| — original post by Modelli}}{{#if:2013-08-12 23:56:48|, posted 2013-08-12 23:56:48}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/22371-rear-lower-control-arm-bolts.html|
Modelli: (2013-08-12 23:56:48)
So i was reading that these have a tendency to break or get seized. As i'm starting to redoing the entire rear suspension, i ordered new bolts/nuts/washers and bushings (for the metal guide needed to install the urethane ones). When i was looking up the part numbers it listed 2 seperate part numbers for the bolts. Is one bolt a standard bolt and the other the eccentric/cam bolt? or are they both cam bolts? This is what i received today, i only ordered 2 of the bolts, because i wanted to confirm i was getting the right ones.
[archived image: 20130812_182714_zpsca60d251.jpg]
Now do I need to order another 2 just like these, or is there a different bolt that i need to order?
G-E: (2013-08-12 23:59:33)
Only 2 of the 4 are supposed to be cam bolts, so the sleeves match the bolts
Modelli: (2013-08-13 00:14:13)
so are the other 2 just standard bolts? Do all the bolts have issues freezing up or just the cam bolts?
862sik: (2013-08-13 04:54:24)
I think its just the cam one, always the passenger side lol. Put anti seiz in that sucker.
i r teh noobz: (2013-08-13 17:45:59)
Only the cam bolts seem to stick. Not sure why. They do that on everything, not just Nissans. 50% of the alignments I get at work can't be done right because the rear toe adjusters are rusted solid, even on cars as new as 2009.
Modelli: (2013-08-13 23:07:24)
probably because of the gap the cam bolt creates, allows more dirt/water inside. I didn't have issues with many cam bolts at work, but for the stubborn ones i have an 8lb mini sledge that normally made them cooperate. Only on the older nissan trucks were they a pita.
Modelli: (2013-09-19 18:15:51)
Anyone have the p#s for the eccentric bushings, when I look them up it keeps referencing me to the bushings I already have(non eccentric).
PrideZ31: (2013-09-20 05:19:40)
About to do the rear control arm bushings myself. My camber is eating my tires, and I'm hoping the new bushings will keep them tight.
adamvann3: (2013-09-20 14:24:01)
All the bushing are non-eccentric. The entire control arm moves with the eccentric hardware, not the bushing.
