Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/flatspotted tires
Imported from Z31Performance.com Forums{{#if:homestar| — original post by homestar}}{{#if:2006-10-23 00:31:31|, posted 2006-10-23 00:31:31}}{{#if:9| · 9 post{{#ifeq:9|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/958-flatspotted-tires.html|
homestar: (2006-10-23 00:31:31)
- %$*%*$*%^&%!!!! I let my Z sit for about 5 months and now on the highway it wants to JUMP off the road. These are brand new yokohamas. Do you think that this problem will drive off the more i break them in or should i buy a new set of tires?
G-E: (2006-10-23 00:44:21)
try inflating them correctly
and do some burnouts to get some heat in them [archived image: smile.png]
homestar: (2006-10-23 00:56:48)
werd i'll find a nice parking lot and do some drifting.
Jason84NA2T: (2006-10-23 01:12:35)
A few heat cycles will tend to make them come back a little.
Also, if you have access to a balancer you should recheck them. Sometimes the balance will go out as a tire wears.
grahfz: (2006-10-23 02:47:59)
we flatspotted a set bad on a rental Mini-S in vegas. Something about large e-brake burnouts…
really bad "thumps" and a bit of hopping… I could see the spots in the tires.
had them rotated at a tire shop, took it behind a nearby business, and burned them off a good bit… mostly to heat them, and try to take the edges off so that they're more round for the return. Wasn't perfect, but was QUITE a bit bitter.
btw, vegas locals LOVE it when you're assing a rental around. ;D Free rotation, thumbs up from anybody who saw it.
Firehawk: (2006-10-23 06:59:52)
It should go away. Overinflate them for a while, and do some "fun" driving including hard cornering. I have had tires sitting longer than that return to normal.
homestar: (2006-10-24 02:32:53)
how much should I overinflate them? I beat the shit out of them today and it was to no avail.
Firehawk: (2006-10-24 07:20:08)
Try about 10psi over normal and then get the tires hot. Be sure to return to normal pressure afterwards.
FlawleZ: (2006-10-24 12:59:32)
Yeah I had 2 Yokohama's that had pretty bad flat spots. Some tard (previous owner) decided to burn out excessively then stop dead and the tires cooled to a nice flat spot. I just burned them some and drove around a little while with roughly stock tire pressure and after ~a month or so I seem to have extinguished any signs of flat spots.
