Forums/Z31P/z31-performance-upgrade-forums suspension-chassis-and-brakes/Aftermarket MBC
Imported from Z31Performance.com Forums{{#if:PulseCode| — original post by PulseCode}}{{#if:2014-02-02 02:27:48|, posted 2014-02-02 02:27:48}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/suspension-chassis-and-brakes/23277-aftermarket-mbc.html|
PulseCode: (2014-02-02 02:27:48)
My master brake cylinder to my '87 daily driver needs rebuilt or replaced. I am leaking a reservoir full in two days time. My first inclination is to go with the OE rebuild kit avaialble on e-Bay for about $85 I think. But, then I read that if there is any corrosion in the MBC body that it should be entirely replaced and I won't know that until I pull it all loose. Are there any good brands available thru NAPA or Car Quest etc. that are reliable and a better value than shelling out around 200 clams for Nissan? This will be my first MBC rebuild but, I'm not too worried about that. Thanks in advance.
Augustus Maximus: (2014-02-02 09:18:27)
MBC manual boost controller. BMC brake master cylinder. I've had luck with used ones.
G-E: (2014-02-02 15:52:45)
Rebuilt is hit or miss like anything, sometimes they rebuild corroded cores too by honing them out a little… best thing to do is crack it open first and then decide, I'm guessing rebuilding would be fine
NissanEgg: (2014-02-02 16:21:52)
The Nissan rebuild kit is NOT $200. Open it up and decide. Rebuilding them is cake. Just make sure to have a few cans of brake clean and a pipe brush to clean out the bore to inspect for scoring/corrosion. Most of the time the lip seals on the pistons wear out and leak.
PulseCode: (2014-02-02 23:25:39)
Thanks. I'm going to get the Nissan rebuild kit for around $85.
Augustus- Thanks, I knew MBC looked funny as I was typing it.
PulseCode: (2014-02-14 19:45:34)
One more question. I looked in the FSM and in the Haynes and neither manual mentions how to remove the reservoir. Does it simply pry out? Thanks.
Z_Karma: (2014-02-14 20:15:16)
Yeah, it pops out.
I can't find it now but, i posted photos awhile ago of the rebuilt BMC i got from NAPA.
It was a oem Nissan core.
PulseCode: (2014-02-14 20:19:08)
Thank You. Yes, I just opened up the box from O Reilleys and it's an OEM Nissan core.
