Forums/Z31P/z31-repairs-forums driveline
Appearance
Driveline — part of Z31 Repairs archive (68 threads).
Threads[edit]
- '89 lsd
- 1986 300zx Turbo Bellhousing.
- 30A rebuild
- 71C Drain Plug Leaking
- 71c weird shifting issues
- 84-87 Transmissons
- 84 300ZX Turbo Tranmission upgrade to FS5R30A
- 84 AE -- Shifter came off in mid-drive
- 84 NA auto trans. What controls it?
- 85 non turbo clutch or tansmission problem?
- Another Torque Converter Question
- Auto Trans Crank used in engine with Manual Trans (Pilot Converter)
- Auto tranny keeps getting stuck in gears
- Auto trans difference??
- Automatic no reverse issues?
- Best Adhesive for Shift Boot
- Bushings -- Manual Trans cross-member
- Can ANYONE shine some light on my tranny swap
- Can anyone shine some light on the idea
- Car won’t move, speedometer is moving
- Clutch Info
- Clutch slave cylinder stroke length z31 vs 350z/g35?
- Fluid change
- GReddy R200 Diff cover compatibility?
- Halfshaft disassembly of inner BDO bearing assy (pic)
- Has anyone rebuilt their auto box?
- Help! Can't find a flywheel!
- Help! T5 NWC vs T5 non world class, can't identify....
- High Mileage FS5R30A and R200 LSD
- How do you measure wheel bearing preload, per the fsm? or torque then crack it off?
- Inner CV seal Kit Boot
- LS1 swap : auto trans choices.
- Lurching on acceleration above 55 mph
- Manual Transmission Swap
- Manual transmission gear oil
- Manual transmission lost 4th gear.
- My clutch all the sudden has a large space of free play whereas before it had none.
- NA Axle Interchangeability
- Need help locating transmission parts for rebuild
- Other strong gearbox options besides 30a? Custom bells?
- Overdrive button does not stay in place once pressed in.
- Price of a 3.545 R200 differential?
- R200 on 84 turbo pops out.
- R200 rebuild or replace
- Re: Transmisson Questoin 30A v 71C input shaft tooth and diameter differences
- Rear left axle
- Reverse switch for t5
- Shifter shakes in 3rd gear - Reverse is hard to catch - bad clutch?
- Small gear grinds and shifter shakes a lot in 4th gear (clutch is NOT slipping)
- Stuck in 5th gear, shifter in neutral
- T5 Transmission No Shift Gasket?
- Torque converter R&R
- Tranny options
- Tranny removal and install w/o removing bellhousing???
- Transmission cooler
- Wheels lag intermittently
- When changing transmission gear oil
- Whining Gearbox
- Z31 clutch and flywheel replacement
- Z31 grinding through gears after rebuild
- Z32 TT transmission swap with bellhousing
- broken plastic ring in turbo AT
- clutch pump replacement
- hydrolic throwout
- input shaft stuck in torque converter
- overhauling cv axle…non turbo
- prop shaft = 27" from the front U joint center to the rear U joint center
- synthetic or conventional
