Forums/Z31P/z31-repairs-forums driveline/Help! Can't find a flywheel!
Imported from Z31Performance.com Forums{{#if:snotnosedpunk| — original post by snotnosedpunk}}{{#if:2018-04-05 13:52:41|, posted 2018-04-05 13:52:41}}{{#if:16| · 16 post{{#ifeq:16|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/539207-help-can-t-find-a-flywheel.html|
snotnosedpunk: (2018-04-05 13:52:41)
Ok I guess the title misleads… I need a flywheel for an n/a 1988 300zx. All I've found is a lightweight flywheel. I just do not have that much money for a flywheel, and on top of that the car is my wife's. As I understand a light flywheel makes it harder to work the clutch? She would absolutely hate that.
so my question. Is there a STOCK flywheel available for my application? If so where? I have been searching for 2 days and can't find it. Any help would be appreciated!
FlawleZ: (2018-04-05 15:19:52)
Here's an 88 Turbo Flywheel. The NA was not listed on Rock Auto
https://www.rockauto.com/en/catalog/…,flywheel,5348
snotnosedpunk: (2018-04-05 15:41:21)
I need one for the n/a… Will the turbo flywheel work with a non turbo computer? Has anyone tried this? My theory is if it would work, why would nissan specified a difference between turbo and n/a flywheel?
It appears they no longer manufacture the correct one??? Wtf? I wish she had just bought a mustang… They're sloppy feeling cars, but at least you don't have to pull your hair out to find parts… Sorry I am just so incredibly frustrated with this.
FlawleZ: (2018-04-05 15:54:54)
The only difference between late model turbo (87-89) and all of the NA flywheels is the NA flywheel is 240mm and the Turbo is 250mm. Its 100% interchangeable the only difference would be the clutch pressure plate used.
Why does the car need a new flywheel?
snotnosedpunk: (2018-04-05 16:00:37)
I can hear the starter grinding where it's missing teeth… So do I have to use a different clutch? I'd prefer not to. I just bought an n/a clutch.
FlawleZ: (2018-04-05 16:04:44)
Thats not a common issue. Have you pulled the starter off to look at the teeth? You're sure the engine isn't seized? The pressure plate needed is slightly larger diameter. The clutch disc itself can be interchanged.
if you need an affordable option, I'm sure someone could sell you their used 250mm pressure plate to match the flywheel.
snotnosedpunk: (2018-04-05 16:10:24)
Engine runs, and starter is new. I hear it every time it starts though. The clutch has to be changed either way. Ya I'd purchase the correct flywheel used, but I haven't found one.
mwolvinm: (2018-04-05 17:32:46)
Vintage Z has a 240mm flywheel for $125. Don't know if it has the ring gear too.
https://vintagezparts.com/product/flywheel-240mm/
But for that price, I'd probably buy the new 250MM flywheel and clutch assy from rockauto.
snotnosedpunk: (2018-04-05 20:29:57)
Thanks for the replies… I appreciate the help. So if I return the new clutch that I have, and then purchase the turbo flywheel and turbo clutch kit will it work? Or is the pressure plate for a turbo car with n/a disc specific to my application?
JSM: (2018-04-06 01:06:16)
I thought the ring gears were replaceable? Can’t you take it to a machine shop and have it replaced?
Also check here. Www.300zxpartsforyou.com
snotnosedpunk: (2018-05-22 18:03:00)
Ok info that was given is not correct. Turbo flywheel and clutch will not work on an n/a car.
The clutch is too big and will bind inside the bell housing.
N/a clutch is smaller and does not bolt up to turbo flywheel.
Use n/a flywheel and n/a clutch for n/a car.
darryl rice: (2018-05-28 23:33:10)
You must have the 71C transmission. I never compared the NA and turbo flywheel. Correct me if I’m wrong, I thought the flywheels were the same size accept for the clutch contact surface on the flywheel, if so you may be able to use a demal or grinding stone in the bell housing. If not I may have my old flywheel with a halfway worn CenterForce clutch and plate… I had the borg Warner transmission behind it
mwolvinm: (2018-05-29 17:38:46)
I'm pretty sure the only difference between a turbo flywheel and a non-turbo is the bolt pattern for the pressure plate (240mm vs 250mm). He may be thinking of the z32 flywheel. Fidanza lists the same part number for Turbo applications as Non-Turbo.
snotnosedpunk: (2018-06-06 16:33:37)
Best to just not give info if you don't know. The N/a clutch will not bolt up to a turbo flywheel. A turbo clutch will bind in the bell housing. Save yourself the headache and pay for the correct part for your application.
mwolvinm: (2018-06-06 17:15:45)
I'm curious where you're getting the turbo pressure plate will bind in the housing. All of the information I'm reading says it'll work as long as it's mated to the correct flywheel. You started the thread, which makes me think you may have tried it without success.
From z31.com:
"The second strongest Z31 manual transmission is the FS5W71C. This transmission is used in the 240SX, 180SX, Silvia, etc. A few people who have blown up their FS5R90As have swapped to this transmission and not had problems."
snotnosedpunk: (2018-06-06 19:45:10)
From z31.com:
Yes. I tried it. It binds up. So I'll say it for the 3rd time use the correct parts for your application.
