Forums/Z31P/z31-repairs-forums driveline/Z32 TT transmission swap with bellhousing
Imported from Z31Performance.com Forums{{#if:ArmyZ31| — original post by ArmyZ31}}{{#if:2019-04-24 09:00:57|, posted 2019-04-24 09:00:57}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/543093-z32-tt-transmission-swap-with-bellhousing.html|
ArmyZ31: (2019-04-24 09:00:57)
I purchased a TT trans 1994 spec and has about 60k on the trans. I am swapping the transmission into my z31. I know there is a forum already explaining the process but I want to retain my bellhousing from the Z32 TT. I already have a z32/z31 hybrid flywheel from AASCO Motorsports. I’m using the 240mm sized flywheel with the ring gear from a TT flywheel which has a 250mm originally. Can anyone please tell me if I will have an issue bolting on the z32 TT starter? will I have to shave any part of the bellhousing? The reason why I’m trying to retain the TT bellhousing is because a pathfinder bellhousing or a z31 30a bellhousing was harder to find. Any insight on the situation will be greatly appreciated.
nismopu: (2019-04-27 15:51:20)
The diameter is not an issue. The TT flywheel is thicker and that's why people clearance. Since you already have a TT trans. It won't be an issue. The diameter spec refers to the clutch surface area and not the ring gear.
ArmyZ31: (2019-04-27 16:37:56)
Oh ok. So the TT starter should work with my combination as well. Would u happen to know if any type of shimming of the transmission or hammering of the tunnel would be necessary?
nismopu: (2019-06-24 02:07:21)
Did you ever get this figured out?
FlawleZ: (2019-06-24 23:32:23)
I don't think the TT starter fits without massaging the chassis.
ArmyZ31: (2019-06-26 13:01:58)
I’ve been away for a minute but when I get back home later in Late July and August I will post pics of the swap. I’ll be as detailed as possible. As long as the starter will mount up fine I should be ok but if it requires “massaging” that’s going to be something I need to address.
govbrown: (2019-08-08 18:08:00)
I'm using a z32 NA transmission, bellhousing, and starter. I had to slightly massage the trans tunnel to get the starter to bolt in. Not much though. I didn't shim the starter and am using a maxima flywheel. Every 20th start or so it misses the flywheel and makes an awful noise.
Augustus Maximus: (2019-10-27 15:35:53)
I have Z32 conversion flywheel new in box.
