Forums/Z31P/z31-repairs-forums driveline/hydrolic throwout
Imported from Z31Performance.com Forums{{#if:rangerlover| — original post by rangerlover}}{{#if:2015-10-27 02:53:24|, posted 2015-10-27 02:53:24}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/25406-hydrolic-throwout.html|
rangerlover: (2015-10-27 02:53:24)
Putting a world class t5 in my z31,it came with a hydrolic throwout . Is it possible to connect it using the existing slave setup?
vgpower: (2015-10-27 07:28:36)
yes just a longer hydraulic hose
rangerlover: (2015-10-27 18:09:33)
New hose from the piece the cylinder connect too or all the way to the master cylinder? I'm old school always had cable clutches,do you know what fittings are needed?
vgpower: (2015-10-27 22:37:48)
all the way from master cylinder
Axel kain: (2015-10-29 12:36:04)
or from the hard line down at the frame rail, over to the new hydro slave.
