Forums/Z31P/z31-repairs-forums driveline/clutch pump replacement
Imported from Z31Performance.com Forums{{#if:fRanK| — original post by fRanK}}{{#if:2017-03-17 14:42:18|, posted 2017-03-17 14:42:18}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/534930-clutch-pump-replacement.html|
fRanK: (2017-03-17 14:42:18)
Hi. I'm looking for the oem clutch pump replacement. I would like the original one from nissan but if not will like to buy the japanese replacement. Any suggestion?
Z_Karma: (2017-03-17 18:53:35)
You mean the master cylinder or slave cylinder. Both are made by Nabco/Tokico. aand easily found via Google.
Master cylinder for turbo and non turbo = 30610-p6500
https://conceptzperformance.com/niss…00_p_25656.php
https://www.nissanpartsdeal.com/part…610-p6500.html
Slave cylinder is dependent on turbo or non turbo
turbo = 30620-48P0A
https://www.nissanpartsdeal.com/part…620-48p0a.html
non turbo = 30620-v5011
https://www.nissanpartsdeal.com/part…620-v5011.html
fRanK: (2017-03-17 19:05:03)
thanks for the info and the correction.
