Forums/Z31P/z31-repairs-forums driveline/71c weird shifting issues
Imported from Z31Performance.com Forums{{#if:Reds86Z| — original post by Reds86Z}}{{#if:2018-12-12 19:55:11|, posted 2018-12-12 19:55:11}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/541890-71c-weird-shifting-issues.html|
Reds86Z: (2018-12-12 19:55:11)
Hi everyone, I'm having a bit of a time with my 86na. When I bought it a couple of months ago it was stubborn going into reverse, the gears wouldn't engage and would just grind when I release the pedal. Occasionally 4th and 2nd would do the same. At other times they engage but not fully, the shifter doesn't go it's full travel but it has gear. Sometimes it shifts through all gears like butter which seems odd to me. I've changed out the gear oil for fresh 75w90 along with the clutch master and slave cylinders. The car has 212 thousand miles so it probably needs a rebuild, but I wanted to see if anyone here has some input as to what my issue is.
Z_Karma: (2018-12-13 02:45:04)
An easy check would be to see if your nylon shifter bushing at the bottom of the shifter is worn or broken.
Reds86Z: (2018-12-13 06:05:28)
I'll check it out, thank you
