Forums/Z31P/z31-repairs-forums driveline/'89 lsd
Imported from Z31Performance.com Forums{{#if:Tempast| — original post by Tempast}}{{#if:2015-01-26 22:06:43|, posted 2015-01-26 22:06:43}}{{#if:14| · 14 post{{#ifeq:14|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/driveline/24698-89-lsd.html|
Tempast: (2015-01-26 22:06:43)
Might be looking at an LSD from an '89-T, guy wants 300 bucks. Good price, or should I save for an OBX helical?
frostvectron: (2015-01-26 22:34:06)
OBX requires a rebuild out of the box to replace shitty hardware.
A CLSD from an 89 will require a rebuild if you want it to lock decently (new clutch plates can be had).
I would go for the CLSD out of an 89. Make sure it is not a viscous type.
Tempast: (2015-01-26 22:45:03)
I mainly want it for street driving, no track use. Is 300 a good deal? Should I have a shop rebuild it before I swap the unit?
Also, I have an '86-T 2+2, my rear end should be a 3.54, and '89-T's should have a 3.7, will it be a big difference 0-60, or highway driving (do almost none of that here)
reddzx: (2015-01-27 01:21:17)
$300 is a very good deal if it isn't beat to shit. They regularly sell for $600-$700.
frostvectron: (2015-01-27 02:44:57)
300 is a great deal. Even if it is beat to crap, you can buy new clutch plates from Gary Savage for ~$100. Just gotta open it up and drop them in there and you'll be set.
adamvann3: (2015-01-27 16:50:28)
If you are rebuilding you can always swap in the 3.54 Ring and Pinion but personally I would keep the 3.7.
I would rebuild with new clutch disks, bearings and seals. Might as well keep it fresh and new.
New2Zs: (2015-01-27 22:10:03)
I'm going obx helical but if I had the option I'd get the clsd.
frostvectron: (2015-01-27 23:44:51)
Relevant info on the OBX:
https://dev.z31library.com/extras_archive/rbryant.freeshell.org/obx_washers.htm
New2Zs: (2015-01-28 03:22:41)
Thanks you just saved me time trying to remember where I saw that lol.
z-flash: (2015-01-30 01:56:33)
I would be all over the '89 LSD for $300 !!!!!!
Parker: (2015-01-30 15:33:42)
I'd pay almost that much just for the finned cover. :P
midian: (2016-01-28 13:53:17)
so, $200 shipped for clsd, but 4.6 (200zr auto) is awesome deal?
Augustus Maximus: (2016-01-30 17:13:09)
Bad deal, let me get it.
midian: (2016-02-02 14:54:17)
man, this set (diff and axles) located at Vladivostok (Russia), shipping will be veeeery expensive, excluding ground (sea) shipping, but I think gear set will be for sale (clsd and axles will be inserted into EUDM case with 3.54 ratio)
well, I also get for $100/shipped 200zr hood (not only scoop, assy) and 200zr auto 7blades dual speed fan (OEM set actually -1 4blades dual speed, 1-7blades dual speed into oem bracket)
