Forums/Z31P/z31-basics how-to-guides-basic
Appearance
How-to guides (basic) — part of Z31 Basics archive (56 threads).
Threads[edit]
- 1986 Turbo GL to GLL conversion
- 71C clutch fork reinforcement
- 89 Heater Core RR
- A few missing parts for my automatic to manual swap
- Affordable 13" Brembo BBK (Big Brake Kit) - ***Zenki and Kouki Hubs***
- Aftermarket A-pillar gauge install
- Assembling 3pc Wheels
- Auto to manual brake pedal
- Boost gauge map sensor bracket
- Brake question for you vets from a newbie
- Camber Modification (garymolitor)
- Converting your Orange face to White face gauges, NA models
- DIY: Bead Roller for Intercooler Pipes
- DIY Lexan T-Top shades write-up
- Does anyone have a template for Idle-up control deletion ?
- Driveshaft Safety Hoop - James Plans Attached
- Easy and/or common z31 modifications.
- Front Wiper washer motor replacement 1986 NA2T
- Hood Struts upgrading to push-on ball design using universal struts
- How-To: Convert to Manual Steering
- How-To: Installing a 2005 Nissan Titan 150 amp Alternator
- How-To: Installing a Z32 BMC without OEM Flare Seat Fitting
- How-To: Rebuild a Holset Turbocharger
- How-To: Short Throw Shifter (T-5)
- How To: Crossmember Swap
- How To: Fix erratic fuel level reading on digital dash
- How To: Installing Titana O2 Sensor in your 84-85 300zx
- How To: Short Shifter 71C
- How To Install/Adjust Greddy Relife Valve (11501710)
- How To Use 3rd Brake Light Spoiler On NON-3rd Brake models
- How to: Install a 240sx short throw shifter in a FS5R30A
- How to 14.7 SLC Pure Plus
- How to Fit Z32 4 Pot Brakes to your 84-86 Turbo or any NA
- How to Install 88 Turbo Rear Vented Brakes on to your 85T
- How to install Z32 Finned Cover onto Z31 Diff V2Diff Mount
- How to use UV dye to trace cabin leaks (and more trial and errors)
- Hunter Alignment Machine PSU Replacement
- Ideas for new or better how to write up's
- Installing New Door Corner Seals
- LED Switch pod bulbs
- Light up bar for 84-86 with LEDs
- NA To Turbo conversion
- Odometer Fix
- Profec B Spec II ashtray mount and tilt mechanism
- RSB-07 Cam sensor
- Soldering/wire repair and connectors
- Suspension
- Suspension Tech from beginner to intermediate
- This forum is set up for guides submitted by forum members
- Trottle Body/TPS solution for vg33er and vg33e intake swaps
- Turbo your NA Z31 (NA2T)
- Upgrade to PRW-2 Ign. Control Module (Power Transistor Unit)
- Walbro 255 Install w/photos
- Water/ alcohol (Methanol) write-up
- request: Jason's (redz31) na2t guide
- understanding offsets, spacers, and wheel fitment.
