Forums/Z31P/z31-basics how-to-guides-basic/Front Wiper washer motor replacement 1986 NA2T
Imported from Z31Performance.com Forums{{#if:rcasey56| — original post by rcasey56}}{{#if:2017-07-18 02:20:38|, posted 2017-07-18 02:20:38}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/how-to-guides-basic/536387-front-wiper-washer-motor-replacement-1986-na2t.html|
rcasey56: (2017-07-18 02:20:38)
I just replaced the front wiper washer motor on my 86 Z with a Trico 11-500 from Oreilly's. Sorry I do not have a lot of pictures but wanted to put this out there in case someone else had the issue. It hooked up perfectly and the only issue is it did not have a mount on it. I removed the old one from the tank and connected the hoses and power connections and it works great. I just placed it on the frame between the bottom of the tank and it will do for now until I take time to permanently attach it. Probably can zip tie the new one to the tank or something like that. Cost was about 20.00.
kaur: (2017-07-18 07:07:15)
Saying motor kind of implies like it's the wiper motor not the washer pump, got me confused at first. Otherwise good to know.
