Forums/Z31P/z31-basics how-to-guides-basic/Assembling 3pc Wheels
Imported from Z31Performance.com Forums{{#if:DeleriousZ| — original post by DeleriousZ}}{{#if:2012-09-12 16:46:54|, posted 2012-09-12 16:46:54}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/how-to-guides-basic/19230-assembling-3pc-wheels.html|
DeleriousZ: (2012-09-12 16:46:54)
First of all I take zero credit for this writeup. It's directly stolen from another forum, written by someone else. I'm just copy pasting it here.
http://forums.pelicanparts.com/porsche- … s-etc.html
Careless: (2012-09-16 15:57:17)
i was gonna ask, where the fuck did you get those FIKSE wheels from and why has i never seen them on your car. then i was sad.
nice cross-post.
amour
slammedfc: (2012-09-20 14:07:35)
=D. Hopefully i'll be doing that soon as the right sight of barrels pops up at the right time.
I
Switchback Motions: (2012-09-20 21:37:22)
GE Silicone II is the most recommended sealant I have found. Just make sure you buy sealant for aluminum or you can experience leaks.
frostvectron: (2013-01-07 21:50:40)
When replacing wheel hardware, is there any special specs needed for the bolts/nuts (hardness, material, etc.)? Will Metric 12.9 suffice?
Also, is it best to assemble with or without loctite/thread locker?
Thanks!
Switchback Motions: (2013-01-07 23:10:23)
Usually most wheel hardware is 10.9 or greater. Personally I'd use known wheel hardware over "hardware store" parts.
Always use blue or medium loctite/threadlocker, you don't want to have them come loose due to vibrations.
