Forums/Z31P/z31-basics how-to-guides-basic/NA To Turbo conversion
Imported from Z31Performance.com Forums{{#if:pokeyquick| — original post by pokeyquick}}{{#if:2014-03-20 13:53:26|, posted 2014-03-20 13:53:26}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/how-to-guides-basic/23482-na-to-turbo-conversion.html|
pokeyquick: (2014-03-20 13:53:26)
I wanted to know if there was any difference in the crossmembers for a 86 turbo and a 87- 89 turbo? I have a 87 NA!!!
88fairlady: (2014-03-20 15:17:26)
You should wait for a more qualified person to answer if you're making a purchase but I believe all turbo crossmembers are the same.
Also, this may have not been the right place to post.
reddzx: (2014-03-20 20:55:56)
same
michaelp: (2014-03-20 21:02:56)
same
Nope. Koukis use larger dia. bolts for the rack brackets. You'll need to have the bolts for the rack to match.
