Forums/Z31P/z31-basics how-to-guides-basic/71C clutch fork reinforcement
Imported from Z31Performance.com Forums{{#if:PulseCode| — original post by PulseCode}}{{#if:2013-01-06 22:46:46|, posted 2013-01-06 22:46:46}}{{#if:12| · 12 post{{#ifeq:12|1||s}}}}{{#if:/Z31performance_archive/forum/z31-basics/how-to-guides-basic/20312-71c-clutch-fork-reinforcement.html|
PulseCode: (2013-01-06 22:46:46)
Since the clutch fork upgrades do not fit into the 71C tranny I decided to try my hand at beefing up a stock one.
I first wire wheeled off all of the factory finish- front and back. Had some 1/8" inch flat bar laying around the shop.
Cut it to length and then tack welded it in place. Finished welding full length beads and filled in bottom, too. Gas
tank ran out right as I was finishing the final bead. It will be a few weeks before I will be able to install and test it.
PulseCode: (2013-01-06 22:50:33)
Thank you 85NA2T for the reference pics and Twisted'Z for the fork to experiment with.
Final pics cleaned up and painted. Make sure the clip is installed BEFORE welding it up!
badboyz31: (2013-01-07 00:06:30)
looks legit, I waas planning on doing this same thing for my track car!!
nice work!!
85NA2T: (2013-01-07 17:21:17)
That turned out really nice.Good job man!
MADMIKE: (2013-01-07 17:30:22)
Good Jorb.
G-E: (2013-01-07 23:54:58)
Looks purdy, but where is the flexing occuring mostly? Not that I doubt this mod improves things, just don't see it eliminating it
PulseCode: (2013-01-09 22:00:04)
Agreed. I want to add more metal to the fork end but, I'm not sure how much I can add and exactly where.
PulseCode: (2013-01-09 23:00:17)
Looks like there's all kinds of room to add metal down the sides. 8)
PulseCode: (2013-01-11 23:01:44)
I drew out patterns with 3/4" masking tape to form the side blanks. They were cut about 3/16" smaller
than the side profile to allow a nice bevel once the welds were ground/ sanded down. Clamped down
against the stock fork. Tack welded in place while in the vice then removed to run full length beads.
PulseCode: (2013-01-11 23:03:45)
Sides welded and blended in- Cleaned up and ready for paint.
Careless: (2013-01-21 05:44:46)
my kinda modification.
nice work.
G-E: (2013-01-21 08:32:14)
Intellesting…
