Forums/Z31P/z31-performance-upgrade-forums engine-mechanical-aa/6262 in stock turbo location?
Imported from Z31Performance.com Forums{{#if:Z31Turboed| — original post by Z31Turboed}}{{#if:2014-11-04 21:41:09|, posted 2014-11-04 21:41:09}}{{#if:27| · 27 post{{#ifeq:27|1||s}}}}{{#if:/Z31performance_archive/forum/z31-performance-upgrade-forums/engine-mechanical-aa/24475-6262-in-stock-turbo-location.html|
Z31Turboed: (2014-11-04 21:41:09)
Is a PT 6262 too big to fit in the stock location?
1985 Z31 Turbo sans AC
FrozenZ: (2014-11-04 22:56:59)
rick88ss is running that. But if you are ditching A/C why not just relocate the turbo, it makes life waaaaaayyyy easier.
HarvesterUT: (2014-11-05 03:12:19)
It looks like rick88ss is also running a VG33. Is that turbo too big for a VG30?
ozzyrulez: (2014-11-05 04:17:11)
As far as I know he's currently running a VG30 and had removed the VG33
Rick88ss: (2014-11-05 05:25:36)
Currently running a vg30 with a 6262. It fits in the stock location even with the bigger S housing.
HarvesterUT: (2014-11-05 23:33:40)
Rick,
If you could do it again, would you stick with the 6262 or go with something else (HX35, etc.)? You seem like you've done this a few times, and I am just getting started. Thanks.
FlawleZ: (2014-11-05 23:37:51)
The 6262 should never be compared to an HX35. That's such an insult…
I'll post a pic of my 6262 in the stock location before my tubular manifolds later tonight.
HarvesterUT: (2014-11-06 00:27:44)
What clutch setup you guys running?
FlawleZ: (2014-11-06 00:49:46)
I'm running the Stage V+ DXD South bend pressure plate with a kevlar solid disc.
HarvesterUT: (2014-11-06 01:16:12)
Good to know. I've driven the DXD stage 3 daily, and I find it easier to drive than my old 350z.
300zxturboftw: (2014-11-06 17:33:06)
This guy…listen to this guy.
Rick88ss: (2014-11-06 23:29:08)
Rick,
6262 is a very good size turbo thay's capable of making over 600whp on about 25-28 psi of boost.
How much power are you looking for? Street or drag/top end performance?
HarvesterUT: (2014-11-07 16:40:14)
Rick,
See my thread about that issue here. But to save you the click, basically, I want to keep my A/C and everything I can in stock locations. Power goal is ~500hp primarily for the street. Don't need a drag monster and certainly don't want to have to flog the engine just to have fun. Wide, mid-range power band is what I like. I intend to build the bottom-end & heads, plenum/exhaust flow, and fuel/ecu work, of course.
Any advice you have is greatly appreciated. Thanks!
Rick88ss: (2014-11-07 18:14:43)
Check out this thread here
http://z31performance.com/showthread…precision+5857
I would go with a 6262 with a T3 exhaust .63 housing
Z31Turboed: (2014-11-16 03:26:02)
Is that because the T3 outlet will bolt right up?
Z31Turboed: (2014-11-16 03:27:37)
I could see how that would be the case.
Anyone still selling a relocation pipe in case I decided to go that way?
Rick88ss: (2014-11-16 17:54:46)
Correct
FlawleZ: (2014-11-18 05:12:26)
This is when I originally installed my 6262. It fits in the stock location better than my old T3/T4. I'll find more pics installed in the car.
FlawleZ: (2014-11-18 05:19:17)
Here we go…excuse the large photos…
lol zomg those fugly brackets I made back in 2010…
HarvesterUT: (2014-11-18 16:45:15)
Nice photos Flawlez. Questions:
- what injector/rails/pump are you using?
- Is plenum gutted?
- Any headwork?
- Did you keep a/c? Is i/c piping still possible with that set-up?
Z31Turboed: (2014-11-20 02:36:42)
Very nice photos. Thanks.
Z31Turboed: (2014-11-20 02:51:49)
Because I removed all my AC components. I can see how it would probably be convenient to re-locate the turbo. Might be expensive…but convenient.
IF…I could still find a relocation setup.
The stock location kind of disagrees with the compressor intake side a bit. That frame member is right there.
Would it be correct to assume that a relocation pipe would have a T4 outlet, not T3?
Flawlez....
Is that still your current setup?
SATAN: (2014-11-27 05:56:49)
I can make you a relocation pipe/manifold with either a T3 or a T4 outlet. A T3 would be plenty for your goals though, and that is what I would recommend.
nismo kid: (2014-11-27 10:23:52)
- Is plenum gutted?
- Any headwork?
Back then he was running stock fuel rails, gutted plenum, DSM 450s (I think), walbro 255, Schneider 274 cams, mildly ported heads, 110lb valve springs, 3 angle valve job. He has no A/C. Here's a video on that set up Flawlez VG30 start up: http://youtu.be/49YSU_LO4K4
nismo kid: (2014-11-27 10:35:21)
Flawlez....
He's since upgraded.
http://z31performance.com/showthread…-RWHP-540-RWTQ
http://z31performance.com/showthread…F-Ignition-etc
FlawleZ Z31 300ZX 540 RWHP Dyno (stock bottom end…: http://youtu.be/iJa5qr4RIIM
amreboot: (2014-11-27 23:59:54)
You can stick a 6765 in the stock location as well.
Thats what I am running
http://z31performance.com/showthread…light=amreboot
http://z31performance.com/showthread…186#post364186
les_joey_paul: (2015-03-28 07:28:11)
Where to find that engine mount turbo inlet pipe though lol.
