6262 in stock turbo location?
  • 6262 in stock turbo location?
    Is a PT 6262 too big to fit in the stock location?
    1985 Z31 Turbo sans AC
    rick88ss is running that. But if you are ditching A/C why not just relocate the turbo, it makes life waaaaaayyyy easier.
    It looks like rick88ss is also running a VG33. Is that turbo too big for a VG30?
    1988 300ZX Turbo Shiro Special
    As far as I know he's currently running a VG30 and had removed the VG33
    Currently running a vg30 with a 6262. It fits in the stock location even with the bigger S housing.
    Shiro #443
    Rick,
    If you could do it again, would you stick with the 6262 or go with something else (HX35, etc.)? You seem like you've done this a few times, and I am just getting started. Thanks.
    The 6262 should never be compared to an HX35. That's such an insult…
    I'll post a pic of my 6262 in the stock location before my tubular manifolds later tonight.
    Originally posted by Andrew84zx
    tell her your car is so fast it will make her panties fly off
    545 RWHP & 540 RWTQ
    What clutch setup you guys running?
    I'm running the Stage V+ DXD South bend pressure plate with a kevlar solid disc.
    545 RWHP & 540 RWTQ
    Good to know. I've driven the DXD stage 3 daily, and I find it easier to drive than my old 350z.
    This guy…listen to this guy.
    Originally posted by HarvesterUT View Post
    Rick,
    6262 is a very good size turbo thay's capable of making over 600whp on about 25-28 psi of boost.
    How much power are you looking for? Street or drag/top end performance?
    Shiro #443
    Rick,
    See my thread about that issue here. But to save you the click, basically, I want to keep my A/C and everything I can in stock locations. Power goal is ~500hp primarily for the street. Don't need a drag monster and certainly don't want to have to flog the engine just to have fun. Wide, mid-range power band is what I like. I intend to build the bottom-end & heads, plenum/exhaust flow, and fuel/ecu work, of course.
    Any advice you have is greatly appreciated. Thanks!
    Check out this thread here
    http://z31performance.com/showthread…precision+5857
    I would go with a 6262 with a T3 exhaust .63 housing
    Shiro #443
  • #15
    Is that because the T3 outlet will bolt right up?
