Forums/Z31P/z31-repairs-forums suspension-chassis-and-brakes-aa/Rebuilding Suspension on 84 AE
Imported from Z31Performance.com Forums{{#if:ralph50| — original post by ralph50}}{{#if:2017-03-29 17:23:54|, posted 2017-03-29 17:23:54}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/suspension-chassis-and-brakes-aa/535127-rebuilding-suspension-on-84-ae.html|
ralph50: (2017-03-29 17:23:54)
My car wants to switch lanes when accelerating on the highway. No wheel spin. Not much hp around 300 detuned.
I just ordered:
Prothane Suspension Bushing Kit
Poly Subframe Bushings
Top and bottom rear Spring Seats
Poly Differental Mount
I'm currently running Eibach with Tokico blues.
While the rear is out is there anything else I should change besides the gear oil???
Might rebuild CV axles but was also looking at 1 or 1.5 degree camber kits???
NissanEgg: (2017-03-30 02:55:12)
Worn bushings will cause a pull under acceleration. You have all the main parts listed in a bushing overhaul job. One other thing to inspect is the toe adjustment bolts and slots in subframe for damage.
