Forums/Z31P/z31-repairs-forums suspension-chassis-and-brakes-aa/88 turbo front brake shims
Imported from Z31Performance.com Forums{{#if:LA z| — original post by LA z}}{{#if:2019-10-07 23:01:03|, posted 2019-10-07 23:01:03}}{{#if:6| · 6 post{{#ifeq:6|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/suspension-chassis-and-brakes-aa/544600-88-turbo-front-brake-shims.html|
LA z: (2019-10-07 23:01:03)
Any body know where to get a set of 88 turbo front brake shins? I’ve been searching without luck. Help. Need a set. New brakes did not come with a set. Car did not have any when I bought it. Thanks.
mwolvinm: (2019-10-08 16:54:29)
Are you talking about the little metal plate that goes between the pad and the caliper?
LA z: (2019-10-08 18:38:26)
Yes. I cannot find it anywhere for sale. Do you have a source? I got some shitty Autozone pads cuz I had a lifetime warranty with them on my previous turbo, but their pads did not come with steel shims. They came with some type of rubber shims.... . Shitty of me to do this, but I need to get this car on the road.
mwolvinm: (2019-10-09 16:59:45)
I don't recall ever putting shims on a z-- Not all cars have them. Just use anti-squeal lube instead.
https://brakeperformance.com/brake-shims.php
FrozenZ: (2019-10-09 18:33:21)
what he said, I've never gotten shims with a set of z31 pads. Just clean the calipers with brake cleaner and compressed air if you've got it when you put the pads in, put some stop-squeal in there.
LA z: (2019-10-11 19:00:06)
Really? My previous car, an 87 turbo had them - factory installed. OK then. Thanks all.
