Forums/Z31P/z31-repairs-forums engine-mechanical/running bad - emergency HELP!!!!
Imported from Z31Performance.com Forums{{#if:akronz| — original post by akronz}}{{#if:2010-02-11 12:45:38|, posted 2010-02-11 12:45:38}}{{#if:17| · 17 post{{#ifeq:17|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/9545-running-bad-emergency-help.html|
akronz: (2010-02-11 12:45:38)
1985 nissan 300zx na 169,xxx manual trans|
Runs amazing cold after about 15 - 20 min seems like a miss fire but rpms wont go higher then 3k. speed decreases greatly feels strange like bad gas so flushed the tank new GOOD gas same thing. please input needed asap cant get online much due to getting laid off from work im getting interviews so if possible call me a 1 330 673 1979. names rick someone who might know what this issue is call me asap
Edit: To explain what it feels like after taking it out a few min ago. sluggish then when stopped cant seem to creep the clutch out of the parking lot wants to stall so clutch in let sit for about 3 min free rev a bit and let loose quick and the movement of the car seems to keep it running but cant leave 3 gear cause its like shes just choking out. :Edit
Rick88ss: (2010-02-11 14:59:05)
1-CAS
2-CHTS
3-AFM(MAF)
akronz: (2010-02-11 19:48:25)
Ok in newb terms, sorry i know maf, (cas chtc you lost me there.)
XiOus271: (2010-02-11 21:19:59)
CAS - crank angle sensor, in the distributor if im not mistaken
CHTS - cylinder head temperature sensor, located in the front of the left cylinder head
Rick88ss: (2010-02-11 21:46:13)
1-CAS
crank angle sensor (distributor)
2-CHTS
3-AFM(MAF)
run the codes and see what you get
akronz: (2010-02-22 20:14:53)
where do i find the damn plug to connect it is it under the hood
RXGhost: (2010-02-22 20:46:54)
you run codes by pulling the ECU down and rotating the diag/idle screw
check the factory service manual on how to read codes
akronz: (2010-02-22 21:04:40)
and where do i see the "codes" is there an lcd display or do i connect it to a obd1 tester?
DeleriousZ: (2010-02-22 21:05:40)
flashey lights.
NissanXRMA: (2010-02-22 21:09:56)
lol. led go blink blink
akronz: (2010-02-22 21:12:26)
thank you… im a newb to this used to old school dodges carb distributer gas brake lol. So this is a learning process as i go - can ya link me to the fsm and what section i need to read to find out the codes
Matt89: (2010-02-22 23:50:37)
Go to an autoparts store, get the haynes manual and learn stuff.
DeleriousZ: (2010-02-23 00:05:31)
download FSM
profit.
akronz: (2010-02-23 03:52:16)
i know you can download a pdf of the fsm offline i had it once before but its lost amongst the millions of other fsms that are printed out and laying around my house in boxes. i mean i even have one for a 1987 nissan skyline for the rb20 cause i did an engine swap with my pal one time and we needed it..
Matt89: (2010-02-23 04:09:59)
quoi
akronz: (2010-02-24 07:11:55)
http://xenonz31.com has the fsm and list of codes pertaining to forum topic.
BLOZ UP: (2010-02-24 19:18:51)
[quote]akronz wrote:
{{#if:DeleriousZ|DeleriousZ wrote:|Quote:}}
download FSM
profit.
So… download it again. what's the problem here?
