Forums/Z31P/z31-repairs-forums engine-mechanical/o2 sensor
Imported from Z31Performance.com Forums{{#if:homestar| — original post by homestar}}{{#if:2006-10-23 01:19:41|, posted 2006-10-23 01:19:41}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/959-o2-sensor.html|
homestar: (2006-10-23 01:19:41)
what is the easiest way to change the o2 sensor. I don't really wanna pull my turbo and disconnect my exhaust because that's a bitch. I'm tempted to just go to a mechanic with the sensor and a hundred bucks and be like "fixit."
Jason84NA2T: (2006-10-23 01:21:07)
If they spend more time, you pay more money… would you rather spend your time or your money?
Spray it with PB for a few weeks before and after driving.
Remove the shield for the brake MC. Use an o2 sensor socket on an extension and pray for the best.
homestar: (2006-10-23 01:25:15)
werd, i'll do that. should i mapp gas torch as well?
Jason84NA2T: (2006-10-23 01:44:46)
it's worth giving it a shot if you can't get it after using penetrant and heat cycling… but the bung nut is 'sinked' into a big chunk of cast iron so it will take a lot of heat.
MrwassmanNA2T: (2006-10-23 03:20:45)
The elbow isn't to hard to pull off itself if you do have issues.
homestar: (2006-10-23 03:58:34)
lets just hope that I don't have issues
FreeLanceBum: (2006-10-23 10:29:03)
I'll second Jason on this, sept I'd reccomend Sea Foam's Deep Creep. Good stuff.
