Forums/Z31P/z31-repairs-forums engine-mechanical/manifold studs.
Imported from Z31Performance.com Forums{{#if:862sik| — original post by 862sik}}{{#if:2009-05-01 07:14:18|, posted 2009-05-01 07:14:18}}{{#if:30| · 30 post{{#ifeq:30|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/7323-manifold-studs.html|
862sik: (2009-05-01 07:14:18)
Hello again. I am currently changing my valve cover gaskets and my drivers side exhast manifold due to A HUGE CRACK lol.
As i was taking off the nuts from the manifold the threads came right out of the cylinder head! Im thankfull they didnt break however the funny thing was, a few of them were very loose and one is missing like it vibrated loose.
I want to know since the stud itself came out of the cylinder head (with the nut i think the nut is seized) can i just put it back the same way it came out? maybe add some loctite? Or should i go to autozone and find some studs, i hope someone has them locally…i cant wait for shipments with this project.
The intake manifold came off rather nicely, took a little time. Im wondering if i should replace the coolant lines that go to the throttle body, to the heater core, and stuff like that.
advice is nice, thanks guys!
RocknTommy: (2009-05-01 13:53:40)
I would not buy studs from AutoZone.
Get them from the dealer. They are improvement from what
originally came on your car.
[archived image: EMS-1.jpg]
I would replace all the coolant and vacuum lines.
You are able to get to them easily since things are apart.
Careless: (2009-05-01 20:11:08)
you can always do the heater core lines later and really you shouldn't be changing them if they are not cracked.
instead, concentrate on getting the proper manifold studs, and go to nissan to get them. They revised them some time after enough complaints from the dealership service reports indicated that the bolts they used were a bad grade and would crack all the time.
YOU CAN use LS1 manifold bolts, If I'm not mistaken (DeleriousZ will chime in here, he posted this item before:
http://www.thunderracing.com/catalog/?a … 3&pcid=301).
you can order those from a local performance shop.
DON'T skimp on these fasteners, or you'll be sorry down the line.
DeleriousZ: (2009-05-01 20:51:34)
those are the correct studs. they're not exactly as they appear in the pics, but they're really really nice hardware. the washers are even belville like the stockers, only about half the thickness.
i'll try and remember to get pics of em installed.
862sik: (2009-05-02 00:23:32)
thanks guys, my dealership had them in stock. it was 75 for the washers, nuts and studs (6). but my buddie was there so i got wholesale price at 45 bucks.
as for the hoses, what ever hoses that didnt need a super bend i got from kregan universal. but the others ill inspect for cracks and going to have to eat it lol.
now, back to work.
862sik: (2009-05-02 18:26:52)
im pissed, the stud that i thought just fell out actually broke a while back and i didnt know. and the other one that i took out i didnt realize it broke in the head. its the rear one, so now that one has no support…i am going to have to drill it out…gerr!!!
DeleriousZ: (2009-05-02 23:11:47)
shitty mate, busted studs are a royal cunt.
edit: pics as promised:
guess who gets to repaint his valve covers!! yayyy [archived image: frown.png] lol
862sik: (2009-05-03 03:44:18)
i noticed i have on that last cylinder hole i have another spot where studs can go into, im assuming it was for like turbo manifolds or something.
i wish i can just get one made so that it fits the other holes. Those 2 bolts didnt budge today, i had the easay out tool from craftsman and it was good until i slipped and then it hit the thread that was exposed, so now it wont come out that easy. My friend is comming over in the morning and he is thinking of just drilling it all out, and tap a new thread. its very tight, i can get my drill in there but its just very tight.
so nothing really accomplished today, i painted the valve covers silver alloy as well as the intake tubing.
Im like :nanan?re going out of my mind, so I stopped working on the car.
862sik: (2009-05-04 01:17:48)
well i got one bolt out, however the other one that was missing to begin with is stuck. AND the extractor broke inside of it!!!!
i got the other manifold from red-zx which i guess is the jdm one that uses the other studs due to the differnt flange. im going to see if a welding shop can chop off the other corners of it and weld it on my manifold lol!
I stopped for today…
On a side note, its easy with 2 people, one pushing and one guiding.
Robyr: (2009-05-04 16:07:47)
Yeah, No easy-outing and easy out. Had it happen on my damn NA collector. Ended up going headers. Hope you have better luck.
Coincidentally, I have a 87T motor i just bought, looks like a stud is missing.... Hope i don't have a broken one in ther. How deep are the stud holes supposed to be? Anyone have the measurements?
862sik: (2009-05-04 18:51:35)
if u went headers, then you still have an issue right?
im probably going to get in there with a dremel.
DeleriousZ: (2009-05-04 19:24:23)
aren't all 4 of the rear stud locations drilled an tapped on the heads? i can't remember, but for some reason i remember seeing one or two banks with all 4 holes drilled/tapped.
862sik: (2009-05-04 19:28:50)
yes thats right. the turbo uses the other stud holes, and one very rare manifold (the one i got from reddzx) uses it.
i was thinking of welding another flange on my manifold lol to catch the other one if i can get this bolt out.
DeleriousZ: (2009-05-04 22:25:12)
not adviseable, your crossover pipe wouldn't work unless you put the correct sized spacers on either side of it to make up for the extra distance.
862sik: (2009-05-04 23:55:20)
oh i was just going to use like the ear of the flange on the other manifold, weld that on to my manifold so that i can take advantage of the other remaining stud holes in the cylinder head.
do these manifolds just crack all the time? cause my car was alwayd missing that top right upper stud....I ASSUMED it was because of force and tention that caused the manifold to crack (hense why im trippin about that last bolt)
but if they do crack all the time should i even worry about that last bolt? or will it even make a difference?
DeleriousZ: (2009-05-04 23:59:48)
the studs crack because they used a poor choice of metal from the factory. they did not account for how long the engines would last (amount of heat cycles) when determining the required fatigue strength of the bolts. they have since corrected this error with the new studs.
one could argue that v8's only use 4 bolts per bank for header studs in some cases, however since the manifolds are split flanges i would advise against leaving it.
862sik: (2009-05-05 00:10:08)
what about the cast iron manifolds, do they just crack all the time?
at the junkyard mostly all of them were cracked. so thats cause of the item and not the way its mounted?
DeleriousZ: (2009-05-05 04:56:10)
cast manifolds crack, find one that isn't and run it till it does.
or if you really want to get down and dirty, make one for yourself then wait till that one cracks.
Guest: (2009-05-05 06:00:02)
I ordered studs for an ls1. cost 12 bucks.
862sik: (2009-05-05 07:44:31)
wish i could just pay someone to make some, however when i go for smog inspection, they will see it and not pass visual.
DeleriousZ: (2009-05-05 15:08:23)
i imagine the stock ones would be pretty damn cheap.
RocknTommy: (2009-05-05 18:29:08)
[quote]DeleriousZ wrote:
{{#if:300cars|300cars wrote:|Quote:}}
$2.90 a piece for the Z31 studs.
Durkin: (2009-05-05 19:26:47)
damn.. they want $3.97 at my local dealer
862sik: (2009-05-05 23:14:45)
i think mine was even more.
862sik: (2009-05-06 06:19:03)
BULLSHIT
I was putting everything back on, and guess wut, snapped another stud. i didnt even reach 14 ft lbs. SON OF A BITCH. Its the one right behind the AC compressor.
So I am forced to remove the cylinder head. I read the book at of course it says set to TDC and remove the timming belt and the distribitor (as well as the other crap). But can i just remove the stuff then get to the timming cover and not even mess with the harmonic balancer? Just release the tension of the timming belt and then slide off the belt off the cam?
also (ill call the shop tomorrow and ask) can i just take out the cylinder head and just leave all the valves and lifters in there if they are just going to tap out a few studs?
ShamWow: (2009-05-06 14:35:28)
Damn I just paid $4 a stud for Nissan ones.
RocknTommy: (2009-05-06 14:58:12)
Was that a new one?
You can leave everything on the head if you are just going to have the studs removed from a shop.
862sik: (2009-05-07 08:31:33)
it was a older one. lol
Let me first say GET THE DARN AUTOPUNCH. I had it but didnt use it till today and its great!!! just make sure its very near center, its the only way these easy outs work.
today my friend came by and said "cant mess it up more, lets tap it out". so im like ok. removed the AC compressor assym and bracket. took a few hours but it came out.
i had a few differnt kinds of easy outs, when one failed i used the other lol.
TIME AND PATIENCE.
so the manifold is back on torqued to 13ft lbs. hopefully tomorrow i can start putting back together the rest.
DeleriousZ: (2009-05-07 14:53:22)
are you unable to read or are you just slow? or did you completely miss my
DO NOT RE-USE OLD STUDS
in your other thread?
i guess you just haaaaad to figure it out the hard way :P i bet you won't do that again.
862sik: (2009-05-07 19:54:43)
hahah yea u got me. i couldnt remove the old ones though…guess i should of tried harder.
