Forums/Z31P/z31-repairs-forums engine-mechanical/fuel pump o ring question.
Imported from Z31Performance.com Forums{{#if:LA z| — original post by LA z}}{{#if:2017-07-06 04:43:44|, posted 2017-07-06 04:43:44}}{{#if:7| · 7 post{{#ifeq:7|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/536281-fuel-pump-o-ring-question.html|
LA z: (2017-07-06 04:43:44)
I have edited this post:
New: I am replacing my fuel pump with a Walbro unit and would like to know where to get a new gasket or O-RING for the fuel pump. This is the part that seals the pump to the tank. If anyone knows where to get one, please let me know. I called Universal City Nissan and they told me that this part is No Longer Available (NLA). If any one has the dimensions of this gasket or O-Ring, please let me know what they are so I may find a replacement.
Thanks,
Original: Universal city Nissan said the gasket - oil ring is NLA. Is that so? Who else sells them?
nismo kid: (2017-07-10 19:06:54)
This is the correct size for the filler neck. I can't remember what size the fuel pump is[archived image: redface.png]. Just use a micrometer to measure it's diameter. Here's a good seller for them. All 3 o rings are 4mm thick. (Sender, fuel pump, & filler)
http://www.ebay.com/itm/201774505743
nismo kid: (2017-07-12 16:44:29)
The Fuel pump o-ring is 108mm x 4mm. The nissan part number is 17344-01P00
https://anciranissanparts.com/nissan…ointvehid=7231
nismo kid: (2017-07-12 16:55:22)
Z31 Filler neck o-ring is 66mm x 4mm nissan part number 17346-01P00. Fuel pump o-ring is 108mm x 4mm nissan part number 17344-01P00. Sending unit o-ring is 90mm x 4mm nissan part number17343-01P00. I posted this just to help someone that's looking for these in the future.
LA z: (2017-07-13 06:41:26)
Thank you guys. Much appreciated
nismo kid: (2018-03-03 14:35:35)
NewJerseyZ It's 108 OD
Dats Z: (2018-12-10 22:21:46)
Is 60mm for the neck filler the OD ?
