Forums/Z31P/z31-repairs-forums engine-mechanical/distributor question
Imported from Z31Performance.com Forums{{#if:mike86z| — original post by mike86z}}{{#if:2008-12-24 19:51:24|, posted 2008-12-24 19:51:24}}{{#if:5| · 5 post{{#ifeq:5|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/6338-distributor-question.html|
mike86z: (2008-12-24 19:51:24)
my distriutor was accidentally taken out without making any marks. whats the best way to install distributor correctly
thanks
13PsiPlease: (2008-12-25 04:36:39)
Buy a haynes manuel. It will be invaluable to you and save you alot of time so you could already be work-en on your car instead of waiting for a answer on this forum.
DeleriousZ: (2008-12-25 22:32:44)
do not buy a haynes.
go and download the FSM.
it has a picture of exactly what the rotor position is supposed to be when installed with the engine at TDC.
michaelp: (2008-12-25 22:54:36)
http://xenonz31.com/reference.html
Advantage to the haynes, though, is you have it right there. If you have a laptop you can have in the shop with you, use the FSM [archived image: wink.png]
kenhill76: (2008-12-26 04:33:34)
FSM is good for knowing what to do and the haynes/chiltons is good for knowing how to do it.
get both
