Forums/Z31P/z31-repairs-forums engine-mechanical/chts harness
Imported from Z31Performance.com Forums{{#if:JoshVG30ET| — original post by JoshVG30ET}}{{#if:2007-03-22 02:59:23|, posted 2007-03-22 02:59:23}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/1914-chts-harness.html|
JoshVG30ET: (2007-03-22 02:59:23)
ok so i went to the dealer to buy my chts…and i had asked for the sub harness to cuz i wanna replace it…but they told me that i couldn't just buy the sub harness…they said i would have to buy the whole wiring harness…[archived image: frown.png]…does anyone know where i can get just the sub harness?
jn1cz: (2007-03-22 03:26:04)
Any dealer should have it. You can def get one from http://www.nissanparts.cc.
Part #24079-01P00
Personally I wouldn't worry about it unless yours is known to be bad.
Firehawk: (2007-03-22 09:17:20)
The harness often go bad at the sensor. Most cars need them, but think that it is only the sensor.
G-E: (2007-03-22 10:16:43)
I recommend making a new harness (ie ripping the connectors off and soldering in new wire) with tinned 18awg cable, less suceptible to corrosion
