Forums/Z31P/z31-repairs-forums engine-mechanical/all show and no go..
Imported from Z31Performance.com Forums{{#if:Dylansmyname| — original post by Dylansmyname}}{{#if:2010-11-26 23:07:08|, posted 2010-11-26 23:07:08}}{{#if:8| · 8 post{{#ifeq:8|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/12698-all-show-and-no-go.html|
Dylansmyname: (2010-11-26 23:07:08)
i have a 84 turbo, cold starts are well lets say cold and brutal. barely stays alive isolates around 500rpm. after if warms up its alright, but only because i adjusted the throttle cable a bit. but my main worry is that sometimes it just wont rev up even at full throttle. sounds like its missing real bad just horrible. so as you can see this makes driving impossible if you have some ideas on what it could be let me know!! thanks
iamrobed: (2010-11-26 23:21:49)
How much do you know about your timing belt? My 85t was acting retarded just like that got a new timing set and magical presto good running car! Still starts slow when cold though but it feels like a whole nother motor
Urstin: (2010-11-26 23:33:21)
There are a lot of reasons why your car could do this, but have you done anything to the car recently aside from adjusting the throttle? Could be a timing issue, but most likely if it was the timing, if you adjusted the ignition timing, that would change it greatly.
I'm just curious though if you have done anything to the car recently before this started to occur.
iamrobed: (2010-11-26 23:43:56)
Also did the car start doing this all of a sudden or has the problem always been there just getting progressively worse over time? Acute or chronic? Backfire through intake?
Just some more details on my car before the new belt: it would jerk under acceleration untill boost came in then it would run good till about 4 grand where it would fall on its face' the jerking was worse under moderate acceleration timing issues can be ignition or cam related
Dylansmyname: (2010-11-27 00:41:43)
yes just changed timing belt about 2 months ago, usually only on start ups would this happen if i didnt let it warm up for about 10 minutes. now its doing it randomly driving. it jerks until about 3k (pretty much only when cold) but then it has some hesitation problems and really doesnt go anywhere between 4k and up. just looked at the spark plugs they have a bit of oil on them not sure why that would be. but maybe im not getting spark sometimes and that would be the reason?
628sx: (2010-11-27 01:33:34)
sound the same?
Urstin: (2010-11-27 03:34:03)
Alright so you hanged the timing belt. If you did that correctly, with all the marks in the FSM lined up then check these things:
Have you checked your ignition timing? With Cyl 1 at TDC and the crank pulley at 0 degrees, the dizzy's rotor should be pointed center just to the right of the dist. housing left screw. Look at a Haynes Manual or FSM, so you don't mess that up.
That could clear up your idle.
The no power at certain RPM's could be an intake leak somewhere, or you need to check your plug wires, and make sure they aren't mixed up or on the wrong tab on the dizzy.
Could be some other things, but these are the easy obvious stuff. I'm sure someone else will post with an idea of what else it could be.
    • both the intake leak, and then the plug wires being on the wrong spark plug caused the same symptons you mentioned. I never told anyone that the plug wires were wrong, because that was embarrassing haha, but it will cause power loss, and misfires.**
Dylansmyname: (2010-11-27 15:26:44)
ignition timings good, i dont heard any leaks, but when i was trying to put spark plug number 6 back when it gave me the hardest time. like it felt like someone cross threaded it or something fell in there, its so hard trying to look at that one with the plenum on. maybe that could cause me some power lose. but it doesnt explain the throttle problem where its not revving up. and i keep tapping on the gas i can eventually get the rpms up but thats the only way
