Forums/Z31P/z31-repairs-forums engine-mechanical/Z31t Engine Oil Cooler Delete
Imported from Z31Performance.com Forums{{#if:Kihnspiracy| — original post by Kihnspiracy}}{{#if:2019-09-17 01:20:00|, posted 2019-09-17 01:20:00}}{{#if:4| · 4 post{{#ifeq:4|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/544462-z31t-engine-oil-cooler-delete.html|
Kihnspiracy: (2019-09-17 01:20:00)
Did a VG33 swap on my z31, but the stock oil cooler has a bad leak. Quick question:
Can I, temporarily, just block off the existing two banjo bolts (on the filter assembly) with regular bolts (and copper washers)? I've been furiously googling and can't find a conclusive answer if these ports can be blocked off or if they need to be looped.
BTW - does anyone know how to get onto the old redz31 website? Whenever I try I get a bunch of virus webpages.
Thanks so much!
IL300zxt: (2019-09-17 14:05:07)
http://redz31.suomiz.net/ is the mirror I know about
FrozenZ: (2019-09-17 19:17:17)
why not just spin off the sandwich plate?
300zxturboftw: (2021-01-13 04:10:09)
Yes. This is what I did to mine with plugs and copper washers til I installed the new oil cooler when I rebuilt the block.
