Forums/Z31P/z31-repairs-forums engine-mechanical/Z31 cranking but not starting
Imported from Z31Performance.com Forums{{#if:itsmenick| — original post by itsmenick}}{{#if:2019-04-27 22:58:04|, posted 2019-04-27 22:58:04}}{{#if:2| · 2 post{{#ifeq:2|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/543138-z31-cranking-but-not-starting.html|
itsmenick: (2019-04-27 22:58:04)
Rundown
getting spark
Getting fuel (to fuel rail atleast)
Starts to get close to running when we spray starting fluid in, after we stop it does after a second
put nodes upto the injectors and they light up
So basically the turbo motor was blown when I bought it. I then bought a na motor and swapped it in with the turbo parts on it.
I do have a code 13 for the collant temperature sensor.
Any help is appreciated
itsmenick: (2019-04-27 23:39:15)
Ok so I messed with the timing a little it starts up and goes to 1k for 2 seconds but then shits off. Another thing I noticed was that when I gave it gas when it starts it chokes it out and shuts it off kind of.
