Forums/Z31P/z31-repairs-forums engine-mechanical/Tranny or Clutch
Imported from Z31Performance.com Forums{{#if:mistah mofro| — original post by mistah mofro}}{{#if:2010-10-11 18:49:39|, posted 2010-10-11 18:49:39}}{{#if:21| · 21 post{{#ifeq:21|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/12224-tranny-or-clutch.html|
mistah mofro: (2010-10-11 18:49:39)
First thing that happened Was after a small mountain run, there was a slight grinding sound. You can hear it right in front of the of the bellhousing, so next day I dropped the tranny retightened the pressure plate and made sure nothing was wrong but everything seemed fine, but theres two stripped bolts on the pressure plate. Second thing that happen made about another "Run" after that there was a very loud whine in 2nd and 3rd, then the next day I couldnt shift into gear like as if the Clutch went. Characteristcs like cant put into gear in while moving or sitting still with the clutch pedal all the way down, so i grab all the essentials clutch/pressure plate/release bearing/pilot.
Now the problem is when I went to go move it for street cleaning it shifting fine, but there was some added vibration at random RPMS. Its a 73 240z with a 280zx tranny also it would throw 5th out of gear, i mean like it would never hold 5th gear this was happening before I had the car though.
So now Im baffled, any ideas anyone?
NicelowZ86NA2T: (2010-10-11 18:54:09)
Re: Tranny or Clutch Assembly?"
You need to drill out the flywheel and put the two broken bolts back in. That will cause your clutch not to be all the way against the flywheel and that can cause problems. Can't see it being a tranny issue.
mistah mofro: (2010-10-11 18:59:10)
Hmmm ok, I have another flywheel. So I guess I should just throw it on then.
P.s- Your avatar is awesome.
Edit Also was wondering if anyone would know where the source fo the whining would come from, someone told me throw out bearing a while ago.
NicelowZ86NA2T: (2010-10-11 19:42:48)
Yes, the throw out bearing can cause whining. Pull it apart and see what it looks like in there. If you got the full clutch kit, replace it all. Rear main, pilot bushing, tob, flywheel, clutch, pressure plate, new front seal in the tranny, etc.......
mistah mofro: (2010-10-11 21:41:30)
Thanks a lot man,cleared up a lot for me. I got the pressure plate/release bearing/pilot/clutch/and flywheel I will be doing today or tomorow.
nismopu: (2010-10-12 01:29:18)
Fifth gear popout is common and can be caused by bad bushings on the tranny mount or excessive play inside the tranny itself. If thats the case its rebuild time and rebuild kits cost about 60-80 bucks. They take about a weekend to do if you have a gear puller set and a vise.
mistah mofro: (2010-10-12 06:03:51)
So i did the whole everything other than the pilot bushing (dam near new), it took about 4 hours on the side of the road but it worked out. Also my pedal was put of adjustment so that helped out aswell. Its really hard to put it in gear but I lost quite a bit of tranny fluid when we put it back. Im going to do tranny flush tomorow and go from there.
Careless: (2010-10-12 07:20:53)
maybe one of the detent balls on your trans is fucked up somehow. if it's hard going in gear and it pops out of 5th, it may be worth a look (consult FSM).
Dave@SBC: (2010-10-12 20:54:51)
Some of Nissans older pilot bushings didn't have the silicone/oil inpregnation correct and could cause a whine. I agree that the tranny popping out of gear sounds like it's tranny related. Please tell me you fixed the stripped out bolt holes. That would couse release issues and vibration.
mistah mofro: (2010-10-13 08:05:14)
Hard Shifting
Yeah I did when I did the clutch job I also threw in another Flywheel and new bolts. I bled the clutch of all its dirty brake fluid until it was clear and I noticed I dont really build pressure from the clutch pedal, also the shifting is really hard now most noticeable in 1st and 2nd gears. Put in some trans fluid and it got alittle better, maybe I need a new tranny or does it seem like the clutch is still messed up?
nismopu: (2010-10-13 13:57:12)
Its cheap to rebuild those tranny's and doesn't take very long to do. If when you accel and decel while holding the shifter in 5th, you will feel excessive movement inside then its probably time for a rebuild.
Dave@SBC: (2010-10-13 14:08:33)
Sounds hydraulic. If you still have the damper in the system, you must bleed it from the bleeder on that as well. You'll never get all the air out if you don't. Some tests; pull the boot back on your slave cyl. and see if there's fluid coming out. If so, it's bad. You can rebuild your master cyl. or buy a new one. If you're still running the stock clutch hose there are stainless ones out there that replace the damper as well. My vendor Zspeedperformance offers one. MSA as well? Another test, remove slave cyl and remove the boot around the clutch fork to the bell housing. Re-install slave cyl and measure the travel of the release bearing. It needs to move at least .400. Have you adjusted the clutch pedal?
If all of that checks out, then may be the clutch. I often have local guys bring in their cheap autoparts store clutches for us to test. They don't always work.
mistah mofro: (2010-10-13 17:46:13)
This clutch is from another L24 the previous buyer (my friend) had laying around, it both the clutch and pressure plate was more meatier than the previous one I had.
Also when the car is off I can shift through the gears semi-smooth (wasnt ever bread and butter to shift) but all that smoothness disappear the moment I turn the car on. On another note I'm not losing any fluid from the clutch master so I wouldn't think the slave can be faulty. I was thinking that something isn't allowing any pressure to build up.
Dave@SBC: (2010-10-13 19:36:58)
lol, when the car is off, there is nothing spinning. Therefor it doesn't matter if the clutch/ hydraulic system even works. I could completely remove the clutch disk from the car and it'll do the same thing.
When adjusting the pedal, spin the threaded rod nearly out of the clevis. Where you can just see it poking through the other side. Does that improve it? if it's a stock clutch in good condition, that should be all the travel you need.
How was it installing the clutch? if you had to draw the tranny in with the bellhousing bolts, you may have bent the disk. OR.. the disk may have gotten bent before you installed it. I don't know the care your friend took with the kit, but it's another possibility.
Did you grease the input shaft? Too much grease can create drag between the disk splines and the shaft. Too much grease can also attract dirt (clutch dust), causing the same issue later down the road. There should be no more then a thin coating.
Last resort, remove the kit from the car. Bolt the kit with the disk inside togther with the flywheel and actuate the fingers of the clutch in a press. You should be able to spin the disk freely at .400 of bearing travel.
If you get frusterated, send everything to me and I'll take a look at it. If you can eliminate the clutch assembly from the equasion, then you can start to narrow down the issue.
Dave@SBC: (2010-10-13 19:46:58)
+1
tranny could be junk. Would explain notchy shifting and gear popping out. I used to have an RX7 that I kept going through tranny's. I got a junkyard tranny for cheap and it was notchy. Used lucas 80/90 gear oil and made evrything butter.
mistah mofro: (2010-10-13 20:06:00)
I was just saying that to ensure that the Trans actually shifts on it own. I did a trans on a Miata and You couldnt even get into gear with the car off. I'll take a look at the pedal and I might (sigh) drop the tranny again, just might buy an entirely new clutch even. But I'll go to all my resorts before I drop it again.
Thanks SBC big help here.
Dave@SBC: (2010-10-14 19:13:57)
NP man, it's how I roll.
mistah mofro: (2010-10-16 09:31:35)
Noticed somethings here and there and thought I would list them:
-Near impossible to downshift from neutral (rev match or occasional luck)
-When I clutch in and out at freeway speeds (50-70mph) vibration in the rear
-Doesn't always feel like its all the way in gear
-1st is ridicoulousy Hard (like im talking about chris brown and rihanna punch hard) to put in gear any circumstance
I was going to mess with the linkage today but due to some things happened earlier, like a melted fuse panel reasons because of a shitty bay area shop (before i had the z) and drained alternator or battery this may put the trans on hold and I may just deal with it for a bit. But i may have a resource for another tranny, thing is he's the same guy welding my suspension on the 240z so I may knock all of it out in one swoop.
Any other ideas?
Dave@SBC: (2010-10-17 03:41:15)
sounds like your trans is pretty well on its way out.
mistah mofro: (2010-10-17 03:52:34)
thinking the same, looks like Ill try to stick it out until i grab another tranny sometime.
mistah mofro: (2010-10-18 01:41:38)
thinking the same, looks like Ill try to stick it out until i grab another tranny sometime.[/quote:2c9rj64m]
Well turns out the the tranny isn't done in completely, i adjusted the clutch pedal alittle more and finally shifted WAY better. Previous was definately done though under some more inspectio the clutch had very slight cracks. Im going to drive it for sometime and maybe bring it back to the mountains and see if i get the same problem.
