Forums/Z31P/z31-repairs-forums engine-mechanical/Tonneau Cover Vinyl Repair
Imported from Z31Performance.com Forums{{#if:TearingRaven| — original post by TearingRaven}}{{#if:2008-01-08 10:19:21|, posted 2008-01-08 10:19:21}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/3939-tonneau-cover-vinyl-repair.html|
TearingRaven: (2008-01-08 10:19:21)
So the part of my tonneau cover that hangs is all split to hell, and the metal brace in it is about to fall out. What sort of adhesive will stick this material so I can seal it up?
RocknTommy: (2008-01-08 14:37:00)
Mine was not that bad but I used Crazy Glue and let it sit overnight
clamped by clothes pins.
A strong epoxy should hold the seams together.
reddzx: (2008-01-09 00:32:31)
I used elmers contact cement and a small brush. I coated both edges a half inch wide and let them dry for about a half hour. Then I cut two strips of wood the lenght of the seam and clamped them every six inches on both sides of the seam.
