Forums/Z31P/z31-repairs-forums engine-mechanical/Timing belt troubles
Imported from Z31Performance.com Forums{{#if:samshadow| — original post by samshadow}}{{#if:2018-01-21 00:48:10|, posted 2018-01-21 00:48:10}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/538434-timing-belt-troubles.html|
samshadow: (2018-01-21 00:48:10)
Hi Everyone,
So I had changed my timing belt and have been having issues with noise. I can get the belt to sound fine without the covers on. Then once i put the lower on it sounds fine until I torque crank. Then i get the noise in the video. Car sounds fine at idle but once you rev it you get the whining noise. I have right around 1/2 inch deflection
Dunkine: (2018-01-22 18:10:47)
Did you measure the deflection with the crank tight? Back the tensioner off a little and see if it goes away.
Timbo_021: (2018-02-10 07:35:33)
That belt looks as tight as a nuns cunt. Should be more around 15-20mm deflection when cold. As it warms up it will tighten up.
