Forums/Z31P/z31-repairs-forums engine-mechanical/Timing belt off by half a tooth
Imported from Z31Performance.com Forums{{#if:itsmenick| — original post by itsmenick}}{{#if:2019-07-07 01:50:34|, posted 2019-07-07 01:50:34}}{{#if:3| · 3 post{{#ifeq:3|1||s}}}}{{#if:/Z31performance_archive/forum/z31-repairs-forums/engine-mechanical/543784-timing-belt-off-by-half-a-tooth.html|
itsmenick: (2019-07-07 01:50:34)
So for some reason no matter how I put the timing belt on, the top left cam is Always off by half a tooth.
itsmenick: (2019-07-07 01:54:09)
New belt btw
jy1235689: (2019-07-08 02:58:34)
The tooth should be vertically below the mark if it's half. Also count the teeth. 40 teeth between the cam marks and 43 between the right cam and crank mark.
